Old 10-20-2018, 11:41 AM   #15
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
Here's a vid of cold start. No revs. My neighbors will hate me enough already. It settles into a nice tone after about a minute
https://youtu.be/duZV2fL22fk
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic
Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's
Torquem is offline   Reply With Quote
Old 10-20-2018, 11:59 AM   #16
Torquem
Bannable
Torquem's Avatar
Also adjusted tips more to sit further in the car. Looks much better.
Old 10-20-2018, 12:22 PM   #17
Sounds great!!
The original link you posted didn't work. Fixed and embedded now.
Old 10-20-2018, 12:47 PM   #18
Torquem
Bannable
Torquem's Avatar
I suck at the internets
Old 10-20-2018, 01:13 PM   #19
Jarret
Drives: 2018 A10 ZL1 - Summit White
Originally Posted by GT-ER View Post
I like this exhaust. What is the performance link pipes?
They replace the secondary cats which makes it louder, you can see how they rate the sound levels here:
http://www.awe-tuning.com/media/Mark...ARO_SS_ZL1.png
Name:  AWE Chart.JPG
Jarret is offline   Reply With Quote
Old 10-20-2018, 03:15 PM   #20
... that's what I'm here for. ^^posted that chart pic up there too.
Old 10-20-2018, 05:20 PM   #21
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
I just installed the axel back dual single tip touring edition on my SS yesterday and love it! Definitely loud on cold start up but it settles down after it warms up. Plus in I few weeks it will be broke in and quiet down just a tad more. DynoSteve at the RDP store took care of me. Great exhaust system for the price!
dmcmahan60 is offline   Reply With Quote
Old 10-20-2018, 05:32 PM   #22
What makes you think it's going to quiet down after break in?
Old 10-20-2018, 05:41 PM   #23
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
The tone will change. Sorry
Old 10-20-2018, 06:07 PM   #24
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
The tone will change and mellow just a bit. From previous exhaust system the raspiness will quiet just a bit.
Actually, exhaust is quietest brand new and will get louder over time.
Old 10-20-2018, 06:21 PM   #25
GT-ER
Drives: 2018 Camaro ZL1
Attachment 961399
Ah I see. I assumed the secondary cat deletes were standard.
GT-ER is offline   Reply With Quote
Old 10-20-2018, 06:55 PM   #26
Jarret
I’m curious as to how the axleback track exhaust is louder than both resonated/non resonated catbacks, anybody have any ideas? Looking to go loud and axleback is much cheaper comparatively.
Old 10-20-2018, 08:48 PM   #27
WEAPON-X
WEAPON-X's Avatar
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC
Had the pleasure of being at Weapon X in Cincinnati today. Awesome bunch of guys. They installed my AWE non res touring catback with performance link pipes. It sounds fantastic. A LOT louder than I was expecting. I'm so glad I didn't get the track setup. I wouldn't call the system drone free. It's not bad though. If you lug it in top gear you will get some cabin resonance. There's some coming up through the gears at part throttle as well. It's about as much as i would put up with. Any louder and I'd have to ad the resonators and/ or secondary cats back in. It sounds absolutely BRUTAL when you roll into it or floor it. I had them poke the tips out a bit to see how I liked the look. I don't know if I will keep it like that or not. Easy to change.
I was curious what my AFR was with my current mods so I had them do a couple dyno runs while I was there.
Only mods - Rotofab dry Cai, Tony Mamo ported throttle body, and awe touring catback with no resonators and performance link pipes.
Found something strange during the dyno pulls. You can see a dip in the graph around 4000 rpm. It's showing the throttle closing a good amount. Blake said he was staying in it the whole time. Did it on all three pulls. No clue what's going on there. First pull was 605 rwhp. Next was 602 rwhp, 571rwtq. AFR hung around 12.5 which I was happy with. Very perplexed by the throttle issue though.
Again I want to thank weapon x. I will definitely be doing some more mods through them come spring.
Glad to hear you're happy man! Sorry I missed ya yesterday.
I'll see if I can get the log to see what's going on, but Blake is obv well versed, so if he said the throttle is closing, he knows what he's looking at. The system deletes your secondary cats, so unless you've deleted the primaries previously and turned the CELs off, it will still have the cats and COT is a setting as well that would need turned off. On my ZR1, it kicks in and takes the fuel from 12.5 to 11.5 AFR. So, seeing your AFR flat line all the way across, it certainly looks like the COT is off to me. Has the car been tuned as such?
COT will show up as a little dip, but the AFR reflects the added fuel almost immediately, especially on our Mustang dyno since the pulls are lonnnnng. I think a 7th gear pull on the A10 is about 15 seconds if I recall, vs. about half of that in 6th; however, 7th is 1:1 for accurate readings.
I would tend to agree with the above statement though, if the car is closing the throttle at a certain RPM, I doubt it's the intake either, it's most likely a flaw with the TB. Regardless, I'll take a look and see if I can help offer some insight.
WEAPON-X is offline   Reply With Quote
Old 10-20-2018, 10:54 PM   #28
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
I didn’t notice the AFR in the posted graph.....and it is strange that it isn’t obvious that it richens up with the power dip.
That being said, my mustang load dyno graph both stock, and with 2nd cat delete catback has the identical dip, in the identical spot, and correlates exactly with the data for COT turning on. A tuner I know said every ZL1 he’s had on the dyno goes into COT on the stock file (but that tuner is kinda iffy). But my car certainly goes in COT no matter what on the dyno,...nothing to do with weather or heat soak either.
ninetres is offline   Reply With Quote
