Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Gen5DIY
Old 10-18-2018, 03:13 PM   #1
590_The_Judge
590_The_Judge's Avatar
Drives: 2018 ZL1 1LE NGM
ZL1 1LE hood wrap
Hello all, my car has 1984 miles on it after 7 months, and as i got into the car today i noticed the hood wrap appears to be pulling up and peeling itself off. I only took pics on one side, but it is happening on both sides.
Anyone else notice this at the corners next to the carbon insert?
Thanks!
590_The_Judge is offline   Reply With Quote
Old 10-18-2018, 03:18 PM   #2
Joszer
Use a blow dryer to heat up the area and iron it down with your finger. Should seal it back up well.
Joszer is offline   Reply With Quote
Old 10-19-2018, 03:18 AM   #3
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 18 ZL1 1LE/18 M3 CP/16 M5 CP
Awaiting the usual garbage answer of “take it to the dealer.”
18 ZL1 1LE
16 BMW M5 CP
18 BMW M3 CP
19 A10 ZL1 1LE (delivered 3/27/19)
URBAN LEGEND is offline   Reply With Quote
Old 10-19-2018, 08:24 AM   #4
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
X2
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
NW-99SS is offline   Reply With Quote
Old 10-19-2018, 08:50 AM   #5
EDFHOBBIES
EDFHOBBIES's Avatar
If the adhesive is still good on the wrap you might 3m edge sealer in a pen or Rtape which is extremely thin dbl sided tape.
Old 10-19-2018, 10:06 AM   #6
ZZebes
My wrap was very poorly done, Ended up having a local wrap company replace it.
2018 ZL1 1LE
ZZebes is offline   Reply With Quote
Old 10-19-2018, 10:19 AM   #7
coruiz
Drives: 2018 Camaro 2SS Hyper Blue
take it to the dealer :belly roll:
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK |
coruiz is offline   Reply With Quote
Old 10-19-2018, 11:22 AM   #8
Tim202
Jeez, I haven't even looked close in that area. Now I'm scared to.
Tim202 is offline   Reply With Quote
Old 10-19-2018, 12:33 PM   #9
URBAN LEGEND
My man!
18 ZL1 1LE
16 BMW M5 CP
18 BMW M3 CP
Old 10-19-2018, 12:46 PM   #10
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Why would you not take it to the dealer this would be covered under the 3 year 36000 mile basic warranty, my car is doing the exact same thing and I will have it redone at the end of the basic warranty for free through the dealer, my 2014 1LE also had a small area that was pulling up and I waited until the last months of the 3 year basic warranty to have it replaced for free
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 10-19-2018, 12:50 PM   #11
ICTsccaCamaro
ITCRNRS
That's what a factory warranty is for correct? If your motor or trans blew up i'm assuming you wouldn't take it to the dealer either?
Old 10-19-2018, 12:53 PM   #12
ICTsccaCamaro
ITCRNRS
Vs. having it redone for free under factory warranty seems like a waste of money?
Old 10-19-2018, 02:05 PM   #13
Drives: 2019 Crush ZLE
They do use a better wrap on the 2019's. Hopefully this will be a non-issue going forward.
Old 10-19-2018, 04:37 PM   #14
590_The_Judge
That you all for the responses. It is still tacky on the backside, i applied pressure rolling it back... no luck. Im going to keep an eye on it and will take it to the dealer under warranty before the three year warranty expires. The post was party a heads up... i saw it, wanted to make sure those more skilled than me could potentially keep theirs in good shape should it happen to other cars.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
