10-19-2018, 10:59 AM | #85 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
^^^Yes, you already posted that. Let's see the datalog that corroborates no heat soak or timing pull, a true apples-to-apples comparison.
10-19-2018, 11:53 AM | #86 |
Drives: 1LE 2SS Camaro Join Date: Sep 2018
Yep this was a big problem in my Audi S4. The 3.0 TFSI engine was baaaaaaad for gunk buildup on valves, Let the car warm up and drive it and try go farther than 5 kms a trip and dont ***** foot it
10-19-2018, 03:54 PM | #87 |
Drives: '17- 1ag37 V6 traded, for 1SS 2018! Join Date: Mar 2018
Not sure my butt dyno would notice. (?)
10-20-2018, 12:37 AM | #88 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I’m sorry, but I have to say your comments about engineers on here and your defenseive statements against people presenting engineering knowledge and/or data is ironic in that it clearly indicates your standing and understanding... With DI, valve deposits come from two major sources: 1. oily vapor and 2. particulate flow-back To my knowledge, DI is good for creating a very closely controlled homogeneous mixture, but is susceptible to a less complete atomized mixture at times. The oily vapors originate from crankcase oil vapor/blowby vapor. The PCV system deals with these vapors. A PCV system consists of a “clean-side” and a “dirty-side” circuit. The “catchcan” system that is factory to the Camaro LT1 is on the clean-side of the crankcase ventilation circuit. Can you guess why it’s called the “clean-side”? The dirty-side, where the PCV valve is, and the circuit that connects post TB is not dealt with from the factory. Why? NOT because it doesn’t need to or shouldn’t; it’s because there isn’t a cheap, easy, non-general-customer-impacting solution. Can you guess why it’s the “dirty-side”? The particulates from flow-back comes from exhaust and is nothing new in an ICE. But why the sometimes poorly atomized mixtures? Well, consider the time the fuel gets to mix with air being the injection point at the last point before combustion (in the camber). The point isn’t that this is exclusive to DI (it isn’t) - it is that it is there, DI still has limitations and it is a contributor to dirty valves. This is where PFI+DI comes in ($$+complexity). With the two sources in mind, since you simply don’t have the fuel physically in the needed location to act as a cleaning agent, you then need to focus on the PCV system (also the simpler area to attack). Besides dirty valves, what do you think oily air does to combustion? |
10-21-2018, 10:13 AM | #89 | |
Drives: 2SS 1LE Join Date: Oct 2011
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
10-21-2018, 10:23 AM | #90 |
Just broke the seal. 60,000 miles was bone stock. Change the oil per the dic
It’s fine. Car kept getting faster with age. Car ran approximately 118mph with only a 26” dr right before I took off the manifold. Until it starts actually effecting something, I’m not going to worry about it.
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 10-21-2018 at 10:45 AM. |
10-21-2018, 10:49 AM | #91 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Can you be more pedantic and condescending? You and rye should get a room together, jeesh! I'd guess you're both young, inexperienced engineers from the way you talk down to everyone. |
10-21-2018, 11:04 AM | #92 | |
Gone but not forgotten:
1998 Bright Purple Metallic Camaro 2012 Carbon Flash Metallic 2SS Convertible 2016 Summit White 2SS Coupe M6, NPP, & MRC Now Driving: 2016 Torch Red Corvette 2LT, NPP, MRC |
10-21-2018, 11:49 AM | #93 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
10-21-2018, 12:10 PM | #94 | |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
And no offence to anyone, but if you are trying to sell something, or even if you bought sonething, it's going to be harder to believe, as you may have monetary motivations for what you say. If we don't know you personally, and since we can't read your mind, there is always that possiblity someone has an agenda.(and humans almost always have an agenda, if making money or rationalizing a purchase)
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
10-21-2018, 12:19 PM | #95 | |
Sure, why not?
10-21-2018, 01:05 PM | #96 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
Thank you for this. Proof that a catch can is not needed. I think they pose a greater risk for doing harm than they do a benifit.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
10-21-2018, 01:32 PM | #97 | |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
What proof is 1 sample size? Do you know any other variables? Highway miles? Racing miles? I hope you are not a lab technician lol What evidence do you have that a CC does harm vs does good? Added oil vapors in the intake system on DI engines not only lower octane levels but coat parts that will never be washed off with fuel. For this one picture I can show you others totally packed with carbon. It has so many variable like driving habits, types of oils, etc. If you don't want one then great, of you do then great. I am not sure why so many guys need to justify "not" having one. |
10-21-2018, 01:43 PM | #98 | |
