Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 07-29-2017, 09:16 AM   #1
ADM PERFORMANCE
Drives: Anything I want
How to add INTERCOOLER RESERVOIR
So we have announced a plug and play Reservoir for ZL1 guys finally. This allows you to be able to check and fill your intercooler as well as add capacity.
ADM PERFORMANCE is offline   Reply With Quote
Old 07-29-2017, 01:14 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
Great job...just ordered it
'17 ZL1 A10 Mosaic Black PDR/Nav 2:04.53 VIR Full 11.08@126.52 1.76
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Old 07-29-2017, 01:49 PM   #3
Drives: 2019 Crush ZLE
Great add... so will a reservoir be following this one?
Old 07-29-2017, 03:05 PM   #4
USP45
Drives: 2017 ZL1 A10
So this will get around having to go to dealer to pull vacuum and fill correct? If so I'm in.... dealer wants $160 to fill and right now have to have special fitting to do it
USP45 is offline   Reply With Quote
Old 07-29-2017, 06:43 PM   #5
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1, 2005 Outback
Why would someone need this exactly? On stock supercharger anyways.
Summit White 2017 ZL1. M6. Roto-Fab, Full Stainless Works exhaust, ATI Damper/15% Lower, Full Xpel PPF. JTM Motorsports Tuned.
Wicked White 2011 Evo X. 5 speed. Full bolt ons, E85. (Sold)
Silver 2005 Outback. Daily/commuter.
Evolvedx27 is offline   Reply With Quote
Old 07-29-2017, 07:33 PM   #6
USP45
On the ZL1 there is no way to refill IC cooling system easily, just about have to go to dealer with their special fitting. And they have to pull a vacuum according to shop procedure as well. If someone (like me) takes SC off for whatever reason the dealer wants $160 to put coolant back in. For $200 I can do it myself at will..... if I decide later to port SC then this will have more than paid for itself.
As mlee asked though, would be nice to have bigger reservoir for more coolant capacity, and could ice the system as well...
Old 07-30-2017, 01:27 AM   #7
Evolvedx27
Evolvedx27's Avatar
How does one check the level? How come this isn't in owners manual?
Old 07-30-2017, 02:21 AM   #8
USP45
No way to on our cars that I know of. With that being said, we really should not have to check it unless we suspect a leak. I do not have the manual with service intervals in front of me, but I would suspect that the IC coolant does not have to be changed but once every 70-100k miles. (If someone has manual handy please feel free to put correct intervals on here). To me this is really more beneficial in that we CAN drain and fill the IC system.... if needed.
I am going to call ADM next week to verify that we will not need to pull vacuum with this system, or that it is high enough to kind of self purge air pockets. If so I am in, if for no other reason as to allow me to do it myself without having to go to the dealer to do it!
Old 07-30-2017, 05:44 AM   #9
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Porter Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2" with high flow cats, 640 rwhp
VAZL1 is offline   Reply With Quote
Old 07-30-2017, 06:57 AM   #10
ADM PERFORMANCE
So I will explain:
So back in 2016 we developed an LT4 Supercharger kit for the 2016 SS Camaro (http://www.camaro6.com/forums/showthread.php?t=444241) and came to the realization that the factory intercooler system needed the ability to fill it wiith out the special filling procedure.
We came up with a group of hoses and coolant tank that fit the bill. This small but useful tank with the correct hoses and placement fit the bill just perfectly.
You do not need to pull a vacuum to fill it,you just need to pour it in and check it.
Does not get any easier than that.It is also completely reversible.
Cheers
Andy
Old 07-30-2017, 07:53 PM   #11
17_zl1
Drives: 17 ZL1
Guys just go ahead and get this, it will make your life much easier trust me. I had my system vacuum bled when i removed my blower to do my pulley swap. The dealer did not even get all the air out and my pump began to cavitate and shut down, I ended up having to put a clear hose on the fill valve attached to a funnel filled with coolant and pushed down the pin with a 1/4 inch extension while jumping the IC pump to burp the system. NOT FUN.
17_zl1 is offline   Reply With Quote
Old 07-30-2017, 09:20 PM   #12
travislambert
travislambert's Avatar
Drives: '17 ZL1
I know a little bit about that...
travislambert is offline   Reply With Quote
Old 07-31-2017, 04:34 PM   #13
USP45
So how do I order one of these? I stopped by the shop today and the shop was closed... or at least the door was locked. Tried to call as well.
Old 07-31-2017, 08:24 PM   #14
ADM PERFORMANCE
I was out of pocket today.
All orders ship tomorrow.
Thanks
Andy
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
