Roto-Fab
Old 01-06-2014, 04:00 PM   #1
RazorLED
RazorLED's Avatar
Drives: 2014 2SS 1LE
Carbon Ceramic Rotors Like Z/28 comming soon!
https://www.sicombrakes.com/vehicle/chevrolet/camaro/ss
Has anyone seen or heard about this company? Looks like they are making a carbon ceramic rotor and caliper setup Soon. does anyone have idea on cost? The ones on the Z/28 save about 28 pounds total, that's pretty significant.
RazorLED is offline   Reply With Quote
Old 01-06-2014, 04:09 PM   #2
RazorLED
RazorLED's Avatar
In 2009 from brembo released this statement here's a link to the complete article:
http://m.autoblog.com/2009/06/02/bre...ith-new-joint/
Carbon Ceramic Discs: Green performance*Compared to traditional cast iron discs, carbon ceramic discs offer significant weight reduction – up*to 50% – and therefore lower fuel consumption. This product is more environmentally friendly, with*lower CO2 emissions, a longer life span, greater corrosion resistance, avoidance of fine particle*dust and performance advantages, as well as a very high level of thermal stability (fading*resistance).*
Old 01-06-2014, 04:22 PM   #3
RazorLED
RazorLED's Avatar
This is a great link about Carbon Ceramic brakes
http://forums.corvetteforum.com/c6-z...onversion.html
Old 01-06-2014, 04:34 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Did you happen to catch the price of them? For that kind of $$, you could add HP mods that would make that 28lb savings nonexistent.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 01-06-2014, 04:43 PM   #5
Synner
Drives: cars
You're ignoring the handling and steering response benefits of lower rotating mass and only considering weight savings effect on acceleration. HP/acceleration is only one piece of it.
Synner is offline   Reply With Quote
Old 01-06-2014, 04:52 PM   #6
RazorLED
RazorLED's Avatar
Yah, your right! It seems besides the weight savings, its not that great.
Old 01-06-2014, 08:30 PM   #7
axis
Search Ninja
axis's Avatar
At $1200+/each for rotors and $1400 for a set of pads, I can deal with a little less steering response.
Halltech CF 102 fed
Old 01-17-2014, 03:53 PM   #8
Crand
Crand's Avatar
Drives: away the ladies :(
Send a message via AIM to Crand
You might also want to go pick up a stack of 4 Camaro rotors. You'll probably think again about that much weight.
Crand is offline   Reply With Quote
Old 01-17-2014, 04:41 PM   #9
axis
Search Ninja
axis's Avatar
For the price of that setup, i'll pick up a IPS twin turbo setup INSTALLED, and drag a whole pallet of them around.
Halltech CF 102 fed
Old 01-17-2014, 07:05 PM   #10
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
LOL
franknbeans is offline   Reply With Quote
Old 01-17-2014, 11:26 PM   #11
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
