Old 12-13-2017, 11:44 AM   #1
Tachitup
Tachitup's Avatar
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1
Torque Spec > suspension, brakes, driveline
I'm seeking to find a reference list of the torque spec for the common fasteners on my ZL1. In particular the suspension, brakes and driveline would be valuable to have.
If someone would kindly direct me to where they would be listed I would greatly appreciated it. Thanks.
Tachitup is offline   Reply With Quote
Old 12-13-2017, 02:00 PM   #2
RXtacy
RXtacy's Avatar
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8
The shop manual is the only place you will find all of the torque values.
RXtacy is offline   Reply With Quote
Old 12-13-2017, 09:18 PM   #3
Tachitup
Tachitup's Avatar
Thanks, but it seems rather silly to go buy a shop manual just to obtain general torque specs. Maybe I'm the only guy you wants to ensure his control arms don't move around on the racetrack ..
Old 12-13-2017, 09:23 PM   #4
travislambert
travislambert's Avatar
Drives: '17 ZL1
Maybe try https://www.repairprocedures.com/
It's legit. I've used it several times. Get a one day subscription for $10 and find and save everything you need.
travislambert is offline   Reply With Quote
Old 12-14-2017, 08:25 AM   #5
Tachitup
Tachitup's Avatar
interesting > thanks.
Did you happen to copy the torque specs ?
Old 12-14-2017, 05:37 PM   #6
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Outside of the shop manual as was already mentioned, another source you might be able to find some things... depending on what you're looking....for is aftermarket companies that sell replacement or upgrade parts to certain suspension areas. like suspension arms, differential bushings, etc.(BMR) You'll have to probably download there install manual.
Or even a source like GM parts performance upgrades. The brake calipers... you can download those manuals too and see what the torque specs are. It'll take a little bit of compiling but most of them you can generally find.
Also I've seen in a couple post on the forms people have posted specs but you might have to use the search function for those. Just throw in somethibg like "Torque Specs" in the forum you are trying to find specs for.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 12-14-2017, 07:17 PM   #7
travislambert
Drives: '17 ZL1
I have some information saved, but not everything. They aren't going to have a a single page with all the torque specs or anything. For example, if you want the specs for the front stabilizer bar end links, you'll go to the section on replacing those end links. In that section you'll find those specs (lower 89 ft/lbs, upper 74 ft/lbs).
$10/Day is minimal for the few times a year I need the information so I don't bother trying to hoard everything. I'd rather pay the fee and have the peace of mind knowing the that information is current.
Old 12-15-2017, 03:15 PM   #8
Tachitup
Tachitup's Avatar
Hey Travis, thanks for sending along the specs that you have. As I get information I'll compile it and that post it all.
Old 12-15-2017, 05:10 PM   #9
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
These are for an ss. But it's probably the same as long as the bolts are the same size
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 12-19-2017, 09:41 AM   #10
travislambert
Drives: '17 ZL1
Here are a few more (Sorry for the overlap from previous posts).
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
Old 12-22-2017, 10:28 PM   #11
Tachitup
Tachitup's Avatar
thanks guys you've been very helpful.
Merry Christmas !
Old 02-18-2020, 09:58 AM   #12
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
Attachment 911905
Wait how is a bolt that is Torque + Turn not a replaceable TTY bolt? Doing the front alignment now and am a little worried about reusing these bolts (Front Suspension Strut Nut At Steering Knuckle).
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 04-14-2023, 04:22 AM   #13
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
It's called TTA and can be reused. Google TTY vs TTA bolt
