06-14-2018, 04:31 PM | #15 |
Thanks for testing it at RA. I won't be going to a high speed track until I go back to COTA on July 13. Thanks for posting on FB, maybe we'll get more testers.
06-20-2018, 11:07 AM | #16 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
posted the PDR data from the fastest session. Unfortunately I have no clue if it would've run hotter with the guards on because I forgot to bring them with me. Worth noting it was 95 degrees ambient!
https://www.camaro6.com/forums/showthread.php?t=531973
MJK3888 Instagram Link
06-20-2018, 07:30 PM | #17 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
I looked back at the data from my last track event (and first with the 1LE) at Grattan (90F+ and sunny all day, zero clouds; set a max temp record for the area of 93F...): The second half of the day I took off the coil covers [that say "CAMARO"]. Since it was so hot out and oil temps would get to 266F at some points (260F was where it was most of the duration of a lap; Mobil 1 0W-40), I wanted to see if I could cool the engine down a bit. I didn't bring much of anything as far as tools, so I couldn't remove the intake cover and insulator and I didn't want to mess with the hood extractors. So, I just removed the coil covers as a"because why not" as they simply pop off.
I didn't notice anything, glancing at the gauges while on track. However, looking at my data, it seems like it made a consistent 2-degree F improvement in coolant temp. In my laps with the coil covers, the coolant temp consistently made a spike to 219F; on my laps without the coil covers, the coolant temp never went above 217F. It's small, but, due to the consistency, seems to be something. To add to it, as far as ambient temperature, the runs I ran without the coil covers, it was likely a few degrees warmer outside, as they were after 12pm. The runs with coil covers were before 12pm. I don't see ambient temp or IAT data listed in Cosworth Toolbox. There are two things I want to do at my next track day: -Check the oil and coolant temp effect of removing the engine cover pieces. -Check the cooling effect between the factory 1LE brake cooling deflectors and the SS track deflectors (I'll have to sacrifice a few sessions to come in early and measure the brake temps ASAP). Last edited by Mountain; 06-20-2018 at 07:46 PM. |
06-20-2018, 08:20 PM | #18 | |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
FWIW your max temps, Trans, Oil and Coolant are the same as mine at Sebring end of April (~85F out) with the guards on I am working on getting Hard data, recording rotor temps live. no ETA though. Though looking at the shields looks like it would help. |
06-21-2018, 08:25 AM | #19 |
Running data would be the most useful
06-21-2018, 09:42 AM | #20 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
2017 SS 1LE.
06-21-2018, 09:59 AM | #21 |
The stock oil cooler doesn't work so well in my opinion. The GM engineers say it is normal to have 260-280 oil temp when tracking. This is absurd to me. I put the mishimoto oil cooler on and ran 95 degrees 90% humidity 6 sessions and my oil temp never go over 239. BTW if you do install it when you have the front clip off you will see a plastic cover in front of the the air filter intake, I removed mine.
06-21-2018, 04:43 PM | #22 | |
06-23-2018, 07:01 AM | #23 |
I was looking at that oil cooler, do you have details or pics of the install?
Here are a few pics from the install. It is a pita to get the front clip off. I did this with a lift, it can be done on jack stands but it is better to use a lift in my opinion. I think the mishimoto oil cooler kit is high quality and fits and works well. I have the plastic piece that covers the fresh air duct from the air cleaner box circled, I did remove mine. If you do order the kit make sure you ask for 200 degree thermostat.
06-23-2018, 07:03 AM | #24 |
doh, helps if I upload the files.
06-23-2018, 09:16 AM | #25 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-23-2018, 10:20 AM | #26 |
Looks like a worthwhile mod to make to reduce the oil temps. While I have the front off I'd like to put on the flowtie grill and sell my glowtie.
I also like the idea to remove the plastic piece that covers the air duct inlet. |
06-23-2018, 08:46 PM | #27 |
I take it you noticed some IAT drops from this? it took me a sec to see the circled p
lol sorry for the pencil edit, the pen and calligraphy pen made the circle so thick it looked like a 4 year old drew it. I don't have any AIT monitoring but I can tell you my butt dyno felt the difference. The cover is probably there to keep water/rain from hitting the air filter. I did do a track day in the rain and had no issues. This is not my DD so it doesn't see much rain at all. To me it makes sense to have clean unobstructed air from the front grill to the air filter.
06-23-2018, 10:22 PM | #28 | |
nothing wrong with that. willing to try it. almost every stock intake usually has some sort of "bong" looking extension to quiet it down or protect from water, etc... its usually a restriction to some sort of degree.
