05-15-2022, 07:52 PM | #1 |
Snow air deflector?
I’m not quite sure the actual description of this piece of large plastic
That seems to block airflow to the radiator on the 22” ZL1, But I know there was a post about removal,while looking at This large part seemingly partially blocking airflow, what is its Stated purpose?, and can it be removed without negative Consequences? |
05-15-2022, 08:08 PM | #2 | |
Drives: 2019 ZL1 Join Date: Mar 2019
I get no water in my intake even washing car. Maybe if it was a downpour and your going 80mph. Other then that it’s pretty useless. Even with it removed it’s still not a straight path.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
05-15-2022, 08:09 PM | #3 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Pulled mine a long time ago. I don't track in the rain so I wasn't concerned.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
05-15-2022, 08:35 PM | #4 |
Thx, but is there a link to remove, I’m not talking about the hood deflector, I’m talking
About the large piece of black plastic in the grill, in front of the radiator. |
05-15-2022, 08:42 PM | #5 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Are you talking about the crash bar? They cover it with plastic for looks.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
05-15-2022, 08:51 PM | #6 | |
Just remove the hood hinge, remove the radiator support, then you'll see the 3 plastic dumb body pins you need to remove. Make sure to have a long body tool to remove them. The bottom one is the pain.
05-15-2022, 09:37 PM | #7 | |
https://www.camaro6.com/forums/showp...23&postcount=5
05-15-2022, 09:39 PM | #8 |
remove the piece and snip the blocking piece off and reinstall...pretty easy and it is obvious what needs to be done when you observe where the air enters.
05-16-2022, 06:06 AM | #9 |
Thanks,and what is the exact purpose for this large piece
Of plastic? Decorative to hide something? Or to Deflect something? |
05-16-2022, 06:36 AM | #10 |
We just told you. It’s to help prevent rain/ice/snow from entering intake.
05-16-2022, 10:08 AM | #11 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Anyone have a picture of what he's talking about?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
05-16-2022, 11:33 AM | #12 |
05-16-2022, 11:34 AM | #13 |
That large black piece of plastic
Runs the length of the grille |
05-16-2022, 01:29 PM | #14 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
That's the front crash bar. It's got a plastic covering over it. The opening in the photo you posted is for a tow hook in case the car is undrivable and needs transported on a flatbed tow truck.
