Old 05-15-2022, 07:03 PM   #1
jchamp922
Drives: 2022 Zl1
Borla S type Axle Back Rattle
Hi,
I just installed a Borla S type Axle Back on my ZL1 and am getting a rattling sound from the drivers side valve when open and closed. Has anybody experienced this?
jchamp922 is offline   Reply With Quote
Old 05-15-2022, 07:34 PM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by jchamp922 View Post
Hi,
Check to make sure the valve isn't loose. If the valve isnt lose and working fine make sure the muffler isn't hitting the heat shield above it.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-15-2022, 08:50 PM   #3
jchamp922
Drives: 2022 Zl1
The valve is tight. I checked and don't see any clearance issues. I am gonna contact Borla tomorrow. This should not be happening with expensive mufflers like this
Old 05-15-2022, 08:52 PM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You sure its the valve and its not hitting anything?
Old 05-17-2022, 03:10 PM   #5
jchamp922
Drives: 2022 Zl1
Spoke to Borla they are sending me a new valve. Hopefully this fixes the issue.
Old 05-17-2022, 06:32 PM   #6
jaybee924
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS
The best thing about Borla NPP is that they are the only ones you don't have to replace the whole muffler if you have a issue with the NPP valve. Actually it's a smart design compared to the others
jaybee924 is offline   Reply With Quote
