04-24-2022, 10:07 PM | #1 |
Drives: 6th gen 16 camaro 2ss Join Date: Apr 2022
I wonder how far the oil temperature goes up if 2SS runs at full speed.
I own 2SS. When travelling at high speed, the oil temperature gauge will continue to point to 261.5. I don't know if it's going up further, but it's already maintained between 1 and 2 minutes at the top speed, and when it's running, the gauge seems to be staying at 261.5. I want to run more, but I wonder if the temperature rises too much. Currently, 5w30 GM stock oil is in it. Is the temperature very high?
04-25-2022, 07:07 AM | #2 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Full speed, you mean track use? I would think the radiators and your coolant might have something more to it than the oil.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
04-25-2022, 08:42 AM | #3 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
That’s the stock oil? I run 0w40 Mobile1 ESP. I thought that was the GM recommendation.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
04-25-2022, 08:43 AM | #4 |
The recommendation was Dexos1Gen2 5w-30 until I think 2020. Not sure what the track recommendation was prior, but Dexos1Gen2 5w30 is still valid for non-track usage.
04-25-2022, 09:12 AM | #5 | |
Drives: 2021 2SS 1LE Join Date: Aug 2020
My guess is if you are running 5W-30, you are currently putting your engine at significant risk, especially if the usage at 260F is sustained. I've already lost an engine while on track, and that was using 0W40 so presumably the cause was unrelated to oil viscosity. So why add another risk factor that you can easily control? |
04-25-2022, 12:44 PM | #6 |
My 19 ZL1 also saw ~270F on track regularly with the recommended 0W-40 oil. With the mid cycle refresh in 2019 came the change of the recommended on all the V8 cars to 0W-40 from 5W-30 in the 16-18 cars. Chevy also made it clear those cars can swap to 0W-40 but it wouldn't hurt to stay at 5W-30 according to them. I personally didn't enjoy the idea of those temps at all which lead to my install of a C&R oil cooler.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
04-25-2022, 12:47 PM | #7 | |
04-25-2022, 06:44 PM | #8 |
04-25-2022, 07:12 PM | #9 | |
04-25-2022, 08:56 PM | #10 | |
04-25-2022, 08:56 PM | #11 |
Drives: 17 Camaro SS Join Date: Nov 2019
What thermostat are you running? I am running a 180 and have never seen the coolant temps above 187 and the oil temps usually lower. Trans and dif about 150.
Flow Tech axle back, Roto-Fab, Nick Williams 103, AEM Wide Band, Defrost vent pod, billet catch can, BBK long tube headers and NGK LTR6GP, #90198, one step colder, Magnuson 2650, Snow Performance water/methanol injection. (Also tune myself w/HPTuners)
04-25-2022, 09:02 PM | #12 | |
04-25-2022, 09:04 PM | #13 |
Where are you driving your car? If you drive it on track, the oil goes to 272F and the coolant to 212-214F.
04-25-2022, 09:06 PM | #14 |
It's stock. When I travel at high speed, the oil temperature rises about 261.5. The coolant is normal. Are you in the same stock? If so, what kind of oil do you use?
