04-21-2020, 11:25 PM | #1 |
Drives: 2018 camaro ss Join Date: Oct 2018
Headers to AWE Catback
I have AWE touring catback exhaust. Going to be getting kooks headers. Will the headers bolt up to the exhaust or will I have to do some mods to make it work?
04-22-2020, 01:49 PM | #2 |
Drives: 2018 1SS M6 Join Date: Feb 2018
cat back is designed to fit factory headers.
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
04-22-2020, 02:01 PM | #3 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Probably need your shop to fab up some connectors or cutting and welding. It's normal for any headers and catbacks.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-22-2020, 02:28 PM | #4 |
Drives: 2018 ZLE Join Date: Apr 2018
The AWE cat back is designed to fit from the 'cats back'.
The AWE system requires cutting a specified distance behind the secondary cats to attach. OP, you will likely have to fab something to attach the headers to the AWE cat back.
2018 ZL1 1LE (CARBON/PDR/NAV)
04-23-2020, 08:48 AM | #5 |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
What if you have the AWE catback with the performance link pipes (2nd cat delete pipes)? No cutting was required then so its like the stock. Would headers bolt right up to that?
04-24-2020, 12:11 PM | #6 |
Drives: 2018 Camaro SS 1LE Join Date: Jan 2020
I have the AWE Cat Back, with Kooks and Cat Delete, you will need to add a two inch spacer to join to the link pipe. Both banks.
04-24-2020, 02:40 PM | #7 |
Jarred
My two inch spacers were made by a local muffler shop, out of three inch stainless pipe. |
04-24-2020, 10:21 PM | #8 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
The AWE will match up to your OEM headers with or without the links depending if you want to delete your secondary cats.
Kooks long tube with free flow cats will connect to your OEM exhaust, but not to your AWE system. Either set up will connect to the OEM, but never shall the two meet! Some welding will be needed, at least that's what I had to do. I was also able to keep my secondary O2 sensors, so no CEL due to header/exhaust system install...just watch that knock sensor on the passenger side...that will throw a CEL if knocked loose!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
