Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 09-05-2023, 03:20 PM   #1
kennyry83
Drives: 2011 Camaro SS
2011 Camaro SS - TSP 427 Initial start up stock ECU tune
I have a built TSP 427 reseleeve I'm about to install in a couple weeks and trying to figure out a good way to go about doing the initial startup/break-in.
I'm wondering if I could do the initial startup heat cycle on the stock ECU, change the oil, trailer it then get a break in tune to do a 500 mile break in. (This is assuming it will start and run with the stock tune.)
Or do I need to just install the engine, trailer it, take it to the speed shop for the break in tune and do the initial start up/head cycle.
I would assume the initial startup would be fine with the stock ECU but figured I would get advice from you guys, notably if others have done this before.
Engine is a TSP 427 resleeve
Cam card s attached
Everything else is factory as of now. (i.e. injectors, throttle body ect will be stock.)
kennyry83 is offline   Reply With Quote
Old 10-03-2023, 01:38 PM   #2
kennyry83
Just in case anyone runs across this thread with the same question... Yes, the car will start up and run fine. Did initial heat cycle break in with factory tune, changed oil, loaded on trailer and took it to get tuned.
Old 10-03-2023, 01:50 PM   #3
kennyry83
Before being tuned (Factory tune with 427 installed)
https://youtu.be/XlhJ0A5mDk8
On break in tune
https://youtu.be/CuYt1aXxsGI
Old 02-25-2024, 05:33 AM   #4
donmeca
Drives: 2013 camaro ss
TSP 427
Was your TSP 427 The Executioner? If it is how has it been holding up?
donmeca is offline   Reply With Quote
Old 03-25-2024, 05:39 PM   #5
kennyry83
It was a custom build. Block is essentially darton sleeved 4.125" bore and 4.000" stroke. Custom grind cam, PRC 260CC heads, 1/2 head studs and forged rotating assembly. Built to take 1200+ crank HP with boost. But holding up great, haven't put boost on it yet or had a dyno tune as I got busy and had to put it on the back burner.
Waiting on new injectors to come in then off to dyno tune.
Old 04-01-2024, 07:32 AM   #6
Scotty D
Drives: 2014 1le 1SS CRMT
Sweet!!
Scotty D is offline   Reply With Quote
