01-09-2021, 07:32 AM | #43 |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
Oh brother...
Yes, you are going to see less skyline in a Camaro with its chopped top. In reality, its no more difficult to see around this car then any other (insert any name\brand here) sport car. That's because its not a design flaw, its a characteristic of a sports car. Keeping the mass of the occupants as low to the ground enhances handling. Additionally, keeping occupants encased in the body of sports cars up to their shoulders/necks improves safety; both under conditions that push the performance envelope of these cars...conditions you wont see in your father's Buick. (LOL, sorry couldn't resist). Like most of today's vehicles, the engineering solutions to mitigate the blind spots and enhance visibility are huge (and appreciated) changes from the previous generations.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
01-09-2021, 09:37 AM | #44 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
01-09-2021, 10:08 AM | #45 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Yes the rear side visibility is bad compared to a vehicle with high windows in the side rears, but only if you are twisting your neck to look behind you.
Then there is the myth about the legendary Camaro blind spots... There are blind spots for those who REFUSE TO PROPERLY ADJUST THEIR MIRRORS because they prefer to see their rear quarter panels when they look in their side view mirrors instead of seeing the cars in the lanes behind them. Believe me, no one ever hit their own rear fenders, or ran them off the road because they couldn't see them sneaking up on them in their rear view mirrors. There are no blind spots with PROPERLY ADJUSTED mirrors. The Camaro roof/rear window do not create blind spots that cannot be eliminated with proper mirror adjustment. I have a convertible, and one could make the argument that the roof and rear window create NO blind spots when the top is down. I assure you I do not have any better or worse visibility in my mirrors with the top up or down. I do not use my mirrors or look behind me any differently with the top up or top down. The only time I have an issue is when making a left at a 'Y' intersection where the view to my right is at an acute angle less than 90 degrees with the top up. The top could block my view to the right, so I have learned to approach those intersections closer to a right angle so I can see to my right clearly out the side windows. Problem solved. |
01-09-2021, 10:14 AM | #46 |
Who Needs to KNOW?
My only issue.. parallel parking - can never see how close you are to car in front and to the curb.
ing for grip.
01-09-2021, 12:51 PM | #47 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Visibility is on the low side compared to a lot of vehicles.
It does disappear after about 10-15 minutes of driving the car and mirrors adjusted properly. Then its pretty much non existant. I thought the same as the magazines until I drove a few and had way too much fun and realized it had zero effect on me. The high belt line is a symptom of women buy more cars than men and complaining about things like NVH. Shorter windows less noise, less issues. This does make for a !$@$T$#@ effect of nowhere to put your arm, smaller windows, taller trunk opening directly leading to a big chunk of the discussion here. As far as the Camaro goes, the roof is fine, lower the damn belt line and 95% of issues people complain about are gone. They do need to find the 2 inches of room in the back that is missing so someone like me could put a fourth person in there. We don't keep the car alive sadly, the masses who buy 4 and 6 cylinders do. If they aren't buying there is going to be problems. One thing I do know, it's a bad ass car in V8 form and if you complain about that, it's time to turn over the mancard for a a purse. |
01-09-2021, 01:07 PM | #48 |
Drives: Radiant Red SS 1LE & ZL1 Join Date: Dec 2020
When I want to see where I am going I drive my super duty.
When I want to drive with a grin I drive my SS. |
01-09-2021, 01:32 PM | #49 | ||
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
I think of a 32 5-Window when I look at a newer Camaro. Remember when phone books were a thing? Pepperidge Farm does. Quote:
The 550 isn’t as bad, but it has a flat bed. When I first got it the bed manufacturer used box aluminum all the way across the cab hoop. I couldn’t stand it so I cut the tubes & welded in 3/8” bar stock to make an open view out the back. I also made the rear gate with a taper in the middle to see better as well. |
01-09-2021, 02:21 PM | #50 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I feel like there are a few things worth pointing out, which other threads have already pointed out:
- Remember that a lot of reviewers hop back and forth between many different cars, and so they never really get used to any of them, and Camaro's visibility is going to look worse in comparison. - As far as a sports car go, there actually isn't too much to complain about in the Camaro, and so the one issue it has becomes a lot more glaring. In the end, you see what you need to see. Pedestrians, other cars, hot girls... What else is there to see in a car? Interesting that someone also mentioned AutoX before. I agree that it's not as easy to see the cones, and when I participated in one event, I do knock over a cone often. I know which one it is exactly, though, and there were some complaints from other drivers as well about how narrow that gate is. Just means I need to get more used to it. Quote:
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
01-09-2021, 02:24 PM | #51 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Only difficulties I ever encounter are drive-throughs at banks and fast food restaurants. Normal driving is never issue
01-09-2021, 02:42 PM | #52 | |
I love my car but I wouldn't describe the visibility as great. Relatively small side mirrors, wing in the middle of rear view, and if you have the seat down low in the driving position it can be challenging to turn around objects. I hit the curb with my right front wheel the first week I owned it.
I point the side mirrors further out than on any previous car like my GTRs. I've gotten used to all of this. Quote:
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 01-09-2021 at 10:22 PM. |
01-09-2021, 09:56 PM | #53 |
Drives: 2018 1LT Camaro Join Date: Aug 2017
I’d really like to know where about the visibility issue is at. I can see out the front, back and side windows just fine. If it’s about blind spots every car has them.
01-09-2021, 10:06 PM | #54 | |
Also, good point that the hardcore Camaro enthusiasts are not going to keep the car alive. It needs to appeal to the masses.
01-09-2021, 10:19 PM | #55 | |
My wife knows nothing about cars and the first thing she commented on when riding in it was how bad the visibility was. Coworkers & friends have made similar comments. There are definitely going to be potential buyers who are turned off by this and look for something else. I’m used to it and found it to be “good enough”, but garage / tight parking lots / drive throughs are where it really stands out. Another scenario it stands out is city street parking where you need to pull in and back out.. the rear and rear 3/4 visibility is atrocious.. could you imagine if the rear camera weren’t standard!
01-09-2021, 11:16 PM | #56 | |
So on one hand, you have Camaro that appeal to enthusiasts but mass buyers don't like. On the other hand, you have BMW that's been watering down their cars to appeal to the masses and enthusiasts have been shaking their heads more and more. So do you dilute? Or do you keep enthusiasts happy but also lose sales? Sent from toaster or something
Current:
