Go Back   CAMARO6 > Marketplace > Members Classifieds > Suspension / Chassis / Brakes
Old 08-30-2020, 08:58 AM   #1
goatjacket
Drives: 2018 ZL1 (sold: 2015, Z/28; 19 1LE)
BMR trailing arms (upper and lower) NIB with bolts
Went different direction and never installed on ZL1.
BMR Upper Trailing Arms Non-adjustable Part #UTCA058 R
BMR Lower Trailing Arms Non-adjustable Part# TCA059 R
These are the stamped red versions, both unopened in BMR boxes.
BMR recommends replacing TTY bolts, so i sourced 8 each bolts/nuts. Including them as package. Looking for $230 shipped!
goatjacket is offline   Reply With Quote
Old 09-03-2020, 04:03 PM   #2
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
how much for just the uppers shipped to canada?
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 09-07-2020, 07:04 AM   #3
goatjacket
Trying to keep everything together at the moment, but I'll update if i choose to separate.
Old 09-07-2020, 07:04 PM   #4
2drstunner
Drives: 2016 Chevy Camaro SS
Will these fit a 2SS?
2drstunner is offline   Reply With Quote
Old 09-07-2020, 07:46 PM   #5
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Yes
driven2exceSS is offline   Reply With Quote
Old 09-08-2020, 09:10 AM   #6
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
ill take the bolts if you want to sell those separate. thanks
Zl1+911 is offline   Reply With Quote
Old 09-08-2020, 10:49 AM   #7
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
PMd you last night.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 09-10-2020, 03:33 PM   #8
chriscamaro69z28
army life
chriscamaro69z28's Avatar
Drives: 2018 hyper blue zl1
Still available
Mods: lingenfelter 15% overdrive pulley, ATI balancer, kooks headers, DSX low side aux pump, DSX flex fuel, GPI stage 2 cam, trans tune, cat delete, rear seat delete, rotofab cai
chriscamaro69z28 is offline   Reply With Quote
Old 09-10-2020, 05:34 PM   #9
goatjacket
Item SOLD
Old 04-04-2021, 09:20 PM   #10
boss4661
Drives: chevy , camaro
I'll take them if you still have them , let me know asap. Thanks
boss4661 is offline   Reply With Quote
