12-16-2016, 08:59 AM | #1 |
Drives: '17 ZL1 Join Date: Jul 2016
Electronic Limited Slip Differential (eLSD) on '16 SS
Has anyone looked into what it would take to get a eLSD to function properly on the '16 SS?
I'd certainly be a buyer for an eLSD upgrade, but I doubt GM will offer it as performance accessory. Obviously, it is possible to buy an eLSD, BCM, new axles, etc. in the form of replacement parts, but I'm wondering exactly which parts would need replaced to get it all to work properly. |
12-16-2016, 09:32 AM | #2 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Only on the ZL1 and 1LE can you get it. It has to be integral to the BCM so I doubt you can retro fit it.
12-16-2016, 09:59 AM | #3 | |
It's hard to know for sure until someone tries it (or at least finds a specific reason why it won't work). When I did the LT4 engine swap I actually ran it for a day or two with a Z06 OS and tune. Things were a little flaky, e.g., it showed 7th gear when in reverse, but it did work and ran quite well. |
12-16-2016, 10:05 AM | #4 |
Drives: 2016Camaro+1968Chevelle+1954BelAir Join Date: Feb 2013
As a gen6 ss owner why wouldent you just buy the zl1? Sorry for probally not being the first to ask you this. But with the lt4 swap and now elsd want what is the reason. I may have missed something. Please explain, i will be trading up to the zl1 next year. Respect for the undertaking tho
"Lead me, follow me, or get out of my way." GGSP
12-16-2016, 10:22 AM | #5 | |
My SS currently has about 70-80 more HP and about 100 more ft lbs than a ZL1 so I'd hate to part with that, but I may still buy a ZL1 next year, especially if the A10 lives up to the hype (my SS is the manual). In some ways, I think I just really enjoy working on these cars and learning what makes them tick. |
12-16-2016, 10:45 AM | #6 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
You will never get past the issue of the BCM. The BCM are programed to the VIN of the vehicle they are going into. You cant use a VIN from a 1LE car to program the BCM for your car as they are VIN tied to your VIN. GM will only send the calibration over that is on file for the VIN of your car.
Unless GM offers this as a dealer supported upgrade it is never going to happen. The 1LE BCM module and the SS BCM are the same part #, the calibration is flashed in at the dealer when the BCM is installed or replaced. |
12-16-2016, 10:57 AM | #7 |
Drives: SS 6 speed of course Join Date: Jan 2016
does anybody know if the eDiff is the standard 8.6 like the SS or is it the typical 9.8" like the last ZL1?
12-16-2016, 12:15 PM | #8 | |
12-16-2016, 12:48 PM | #9 |
Stick with it, that will be a bad ass ride. And i agree the experience of driving a hot rod you built vs one you buy makes it that much more self rewarding. Best fo luck with it!
12-17-2016, 07:16 AM | #10 | |
12-18-2016, 04:23 PM | #11 |
I've been looking over the eLSD wiring diagrams and it looks as if this might actually have a chance of working. The GM LAN connection is spliced between then Chassis Control Module and Suspension Control Module. And there is a shared signal wire (Serial Data Communication Enable) from the BCM that could be spliced in pretty much anywhere.
So in other words it appears the new Rear Differential Clutch Control Module uses existing outputs from the Chassis Control Module and Suspension Control Module via GMLAN. Of course, there is still potential for software misalignments, but at first glance it still seems plausible. |
12-24-2016, 11:20 AM | #12 |
Drives: 2016 Camaro 1SS Hyper Blue Metallic Join Date: Jun 2015
Considering what Tim @EFI has done with E85 flex fuel after being told it couldn't work I believe anything is possible with these cars.
"Ask not what the camaro can do for you but what you can do with your camaro."
12-24-2016, 12:58 PM | #13 |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
Why wouldn't it be possible? If everything in the car (including the wiring) was switched out with ZL1 parts, the car should be able to have everything that the ZL1 has. Sure the cost would be outrageous but this is simply to say that it is possible.
Now obviously you don't want to swap EVERYTHING so you just have to figure out what has to be done to make it work and if the cost is worth it to you. I'm sure is possible, it's all about how much you are willing to spend to make it happen. That and having the know-how or knowing someone who does.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
12-26-2016, 06:56 PM | #14 |
If you can get Chris White to program your BCM, then that will be the only way you will get this mod to work. Now with that, there is a cavet. It will work s long as you never let the dealer ever flash your BCM for any reason at all, if they ever do it will return your BCM to the on file calibration that GM has in their system for the options your vehicle has and that are tied to the VIN.
As I said earlier, this isn't a simple hard part issue. Any time you get into something that has calibration programming requirements then you are going to run into issues on the new cars. For years the guys on the GM truck forums were just sure they could get the factory OEM trailer brake controller swapped over, 3 years down the road and you still cant get the OEM TBC in a truck that didn't come with one. |
