06-13-2023, 12:45 PM | #1 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Cooking Brake Pads and Fluid
Had a bit of a scare at Road America. I bled my brakes with Castrol SRF back in April. Did 2.5 events at Road America on OEM pads and take offs. Ambient temps never got higher than 45F. Pad back plate never even discolored from the black paint. Had another event this past weekend. Got a used set of Ferodo 1.11s off of FB market place. Seller said they had 2 track days on them. Bedded them on the highway the day before the event and trailered. Saturday was warmer, upper 70s at the highest, don't think it broke 80. Was having really long pedal travel with the pads. Felt worse than OEM, but kept using them. Second session of the day, pedal travel was getting worse and worse. Pedal eventually went to the floor on turn 1, but was able to slow down without an incident. Bled my brakes and swapped to new 1.11s. Taking off the used 1.11s, they were glazed.
Anyone ever experience this? Not sure what caused the pads to glaze and boil my fluid. I figured 2.5 sessions on fresh SRF and low ambients shouldn't have been a problem with SRF. Especially since I've read some posts of people bleeding once a year. Previous owner didn't bed the pads properly? Just pushing too hard? I will have to go through my PDR footage, but I don't recall activating ABS, so I never exceeded threshold braking. After swapping pads and fluids, didn't have a problem. I have SS deflectors, but I forgot to bring them. That won't happen again and will always bleed brakes before events going forward.
06-13-2023, 01:26 PM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Well, pedal to the floor means you were definitely getting an issue related to brake fluid. Was it fine after bleeding them or did you still have the issue?
Could be several things, most likely you got too much moisture in your fluid. I've never had any issues even with changing compounds or running in warmer temperatures. The hardest I've even ran my car was a 1 hour long session at VIR north course. Really hard on brakes and I never had a single issue with soft pedal or anything else. If you ever get a soft pedal in a session don't keep driving, should be addressed right away. It's not normal and indicates some sort of problem. |
06-13-2023, 02:17 PM | #3 | |
After I changed the fluid and pads I didn’t have any issues, ran 6 more sessions over 2 days. Like I said will bleed the brakes every time now. Don’t want that feeling again.
06-20-2023, 09:38 AM | #4 |
RedLine
Swap to Hawk 70/60. You will thank me later!
They do run hotter than the stock pads and will cause microcracking of your rotors over time however they stop better, and have no fade. Front: HB631U.622 Rear: HB194G.570
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold) 2018 CTS-V "Black" (Sold) 2022 GMC 2500 "Blue" 2022 ZL1 1LE 6spd "Rapid Blue" 2023 ZL1 1LE Auto Rapid Blue (ordered) |
06-20-2023, 10:35 AM | #5 |
How did things go with the new 1.11 pads then?
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
06-20-2023, 10:39 AM | #6 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
Keep seeing to many people state do not stagger the pads on these. The systems to good from the start to do this. Staggering only means you’re putting more work in on the front pads and can causing heating issues in the front. If GM properly set the proportioning value up correctly, then don’t stagger.
06-20-2023, 11:06 AM | #7 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Pad fade is still going to be a mostly firm pedal but decreasing friction to no friction. I think pad fade can have some minor pedal softening like during bed-in but that's more of a lengthening pedal. At some point, moderate to severe softening pedal is fluid. SRF has a trait of hot compressibility, at some point the hotter it gets it will start to create a soft pedal. Once cooled to ambient the original firm pedal returns, assuming the fluid never got to the next level of boiling. Once fluid has boiled the pedal stays soft. Did that fluid ever get a chance to cool to ambient and if so how was the pedal? The pads look like they overheated but then the fluid got hot enough to the point it may have started to boil or a very severe case of hot compressibility.
Do you still have the OE ZL1 brake deflectors or have you upgraded to the Caddy Blackwing deflectors?
06-20-2023, 11:10 AM | #8 |
ive been running hawk dtc60 for last 2 years and doing some time trails events and hpde and never had any issues motul 660 fluid girodisc rings goodridge ss lines
06-20-2023, 11:53 AM | #9 | |
06-20-2023, 11:56 AM | #10 |
After changing the pads and bleeding the brakes, I didn't have any issues. Ambient temps were about 25 degrees cooler the next day. I bled the brakes again when I got home. 4 press and releases for each nipple, so 8 per caliper. Fluid looked new.
06-20-2023, 11:58 AM | #11 |
Drives: Cadillac ATS-V Join Date: Feb 2023
Aggressive track pads require more heat to be effective than OE HP1000s...and rear brakes will not generate the same amount of heat as fronts. That's why staggering compound is so frequently recommended, as a lesser compound in the rear will be closer to its optimal heat zone faster.
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber |
06-20-2023, 11:59 AM | #12 | |
Pads look cooked to me. Haven't thrown them out yet, going to see if I can email Ferodo about them. I have the OE. I can't get my hands on the blackwing. I have the SS brake deflectors, but I forgot to put them on before the event and left them at home (won't happen again lol). I saw one member post the differences in temp between the SS and blackwing deflectors and they were more or less the same temps, so I'm fine with using these.
06-20-2023, 12:26 PM | #13 |
i hear you! hawk has me hesitant anyways for destroying rotors. ive only run carbotech, just hate they are the most money now! i think XP12/12 is all that is needed as its higher heat temp over even the hawk70 and its nice to rotors. not sure who needs the XP20's at 2000+!
06-20-2023, 12:30 PM | #14 | |
