01-26-2018, 11:14 AM | #43 |
Drives: 2016 Red Hot 2SS Join Date: May 2016
I have one lying around, check my this thread
http://www.camaro6.com/forums/showthread.php?t=513874 |
12-10-2018, 09:48 AM | #44 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Any new thoughts on keeping the battery charged over the winter?
I can press one of my old Battery Tenders into duty or pick up one of the CTEK 3300s pretty easily.
05-10-2021, 05:33 PM | #45 |
Drives: 2018 Camaro 2ss 1le Join Date: Mar 2021
05-10-2021, 10:47 PM | #46 |
Drives: 2020 ZL1 Exorcist Join Date: Mar 2021
This is what I have. There are terminals in the engine compartment that I hooked into. Worked like a charm. He fired right up after a long winter’s nap.
‘20 ZL1 Exorcist #52 Riverside Blue A10
05-11-2021, 03:16 AM | #47 |
Drives: 2018 Camaro SS Join Date: Jan 2021
I went with the Noco to over the Ctek. Charges more types of batteries.
Works like a charm Sent from my iPhone using Tapatalk |
05-11-2021, 06:26 AM | #48 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I always keep my camaro plugged in to a tender.
But there are risks. Several years ago we had a near lightening strike. Surge came thru the house, and thru the tender plugged into my C6 corvette. Did like $3300 damage to the car as it blew up the BCM, and two ABS sensors. Completely smoked the battery tender, I mean charred burnt carnage! So now if I even think there is chance of t-storm...I unplug the cars.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
05-11-2021, 09:07 AM | #49 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
I have connected directly to battery, just made a small hole in the cover to feed the end through, can pull out like a foot of cord when needed and tuck in out of the way when not being used
05-11-2021, 09:21 AM | #50 | |
Sure, why not?
As someone pointed out earlier, CTEK makes the chargers that GM sells for the Camaro, so I tried to get one that appeared to be as close to that as I could. Not sure how well I did on that part, but here we are in 2021 now and my original battery is still going strong. The car sits in a 40° garage all winter, plugged into the CTEK. BTW, the CTEK comes with a nice pigtail with (what do you call them?) the round hole ends so you can bolt the pigtail to the battery securely. On the other end of the pigtail is a nice connector that only goes on one way, to attach to the lead from the charger body. I find that the rubber gasket around the trunk opening is forgiving enough that I can close the trunk lid over the charger lead for the winter. I have the pigtail coming out the edge of the little carpet door near the battery. When not needed, I just stuff the pigtail back in there. Plenty of room.
