05-16-2017, 08:48 AM | #1 |
Drives: 2017 camaro LT v6 Join Date: Apr 2017
Why does my 2017 v6 manual camaro lag when i hit second gear?
Every single time i hit second gear it lags a bit and it feels like im putting pressure on my drivetrain. Anybody know why this happens?
05-16-2017, 09:44 AM | #2 |
Drives: 02 Camaro SS 6M / 11 GMC Sierra Join Date: Mar 2017
That doesn't happen to me at all you are talking about a six-speed manual right?. Has it just started happening do you think you could be bad gas you might want to take it in to get it checked out.
In all fairness though I'm still doing the break-in. So if you're shifting a 6500 or 7000 RPM I have no idea how that will yet. How many kilometers/miles are on your car |
05-16-2017, 09:53 AM | #3 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
I had some trouble getting the pedal modulation right and would experience this. It took quite a few thousand miles for me to get used to it... I just wasn't properly mixing the the throttle application / clutch uptake.
05-16-2017, 10:24 AM | #4 |
Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
05-16-2017, 02:13 PM | #5 |
Drives: 2017 2SS Stick Hyper Blue Join Date: Jan 2017
Could it be the infernal gizmo built in that shifts directly from 1st to 4th under certain conditions? I have trouble with this on occasion.
Whoever thought up this stupid gimmick should be condemned for eternity to have it on every car he ever owns! By the way, I think this gizmo was a bad idea! LOL! |
05-16-2017, 02:21 PM | #6 | |
Drives: 2016 2SS / 2004 Tacoma Join Date: Feb 2016
2SS, Manual, Blue Velvet Metallic, Medium Ash Grey, Black Wheels, MRC, NPP, Black Bowties, Black GM Tail Lights, Oracle LED side markers.
"I'm going to drink you pretty, beautiful toad" |
05-16-2017, 02:25 PM | #7 | |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Honestly I haven't really had it even try to force but a handful of times, but I agree the eliminator is a cheap fix, I may try it.
05-16-2017, 02:26 PM | #8 | |
Drives: 2LT/1LE, HPCRX, F250(tow vehicle) Join Date: May 2016
As for the OPs original question, it's related to the infernal delay GM programmed into the throttle pedal. It's horrible, and yes you can get used to it with time but I still hate it. I even had my son in law look at the programming on mine when he had it at the dealership last month. No problem, it's working as they designed it.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone' Bruce McLaren |
05-16-2017, 03:26 PM | #9 | |
Drives: 2022 2SS A10 NPP MRC Red Hot Join Date: Aug 2016
Its really not an issue though; don't try to shift to second at 1500 or 2000 rpm. It seems that is when it activates. Wind up to 2500 or 3000 rpm when going to 2nd and skip shift isn't an issue. Not sure if its on a V6, if so, the rpm s may be slightly different; but you get the idea. Last edited by jreagle56; 05-16-2017 at 03:28 PM. Reason: wording was incorrect |
05-16-2017, 03:52 PM | #10 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
05-16-2017, 04:00 PM | #11 | |
I agree about the delay in the throttle pedal. I bought a throttle controller and it helps, but I've since quit using it and drive the car as it was designed. I'm used to it now. |
05-16-2017, 04:09 PM | #12 | |
05-16-2017, 05:07 PM | #13 |
Agree! I gave my elimator away sincs its never been an issue.
05-16-2017, 05:27 PM | #14 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I have the LGX with 6 speed and I have found 1-2 gears are really close together. I very rarely use 2 gear but have no issues with the way it pulls. About the only time I use it is when I am still crawling and don't have to come to a complete stop. The LGX does not have the 1-4 skip, thats only on the SS to meet federal fuel regs.
