12-24-2016, 05:20 AM | #1 |
Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
Where is the transmission dip stick on a 2010 Camaro 2SS?
Where is the transmission dip stick under the hood of a 2010 Camaro 2SS? I'm assuming there isn't an access point under the hood unless told otherwise.
12-24-2016, 05:41 AM | #2 |
Drives: 1SS-2013 Join Date: Jul 2016
12-24-2016, 06:52 AM | #3 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
There isn't one. The fluid must be injected into a port on the side of the trans where a dipstick/fill tube would be. This only after the fluid is checked at the proper temp and conditions. If you don't see any trans fluid leaks, don't worry about it. I'm not happy about it either: I like being able to check and maintain my fluids, too.
12-29-2016, 01:12 PM | #4 | |
We will be offering bolt in dipstick tube kits so one can properly service and check they transmission fluid from under the hood like it should be. Ted.
www.jannettyracing.com
01-13-2017, 07:21 PM | #5 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
