Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 03-25-2017, 11:03 AM   #1
Blackbat27
Drives: 2010 chevy camaro V6
Exclamation Help me lol. 2010 3.6L knocking.
So I've had a knocking for about 2 years now. I believe it is a spun connecting rod bearing. I also have a check engine light on with a code for a bad timing chain. I'm really lost on what to do. I need to find a new or used engine but I've had absolutely no luck. My budget is around $3700.
Blackbat27 is offline   Reply With Quote
Old 03-25-2017, 11:32 AM   #2
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
You can buy a short block from GM for around that price. Are you handy? Great learning experience!
O.F. is offline   Reply With Quote
Old 03-27-2017, 08:53 PM   #3
BumbleBeeV62011
Drives: 2011 Camaro 2LT/RS
If I remember correctly a short block is the block with the crank, rods, and Pistons installed. If the heads are not on the engine I highly recommend you let a professional do the work because if you don't get the cam timing right you will be right back where you started
BumbleBeeV62011 is offline   Reply With Quote
Old 03-27-2017, 09:48 PM   #4
O.F.
O.F.'s Avatar
Short block would be timed already.
Old 03-28-2017, 07:30 PM   #5
Blackbat27
Thanks guys I think I've found one 2995 with 3 year warranty. Not to bad I'm just going to have a shop drop it in. I have the knowledge but not the time.
Old 03-30-2017, 01:08 PM   #6
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
Where did you find that? I got a junkyard engine with 50k miles on it for the same price but no warranty.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
djrasras is offline   Reply With Quote
3.6l, engine, knocking
