07-20-2010, 09:19 AM | #1 |
Drives: Summit White 2ssrs inferno Join Date: May 2010
Need Your guys help ASAP, Please!!
Im in the middle of my installation and have a few issues, any help would be very appreciated.
I have two 12 inch kicker cvr with dual voice coils rated at 2 ohm and a kicker zx 750.1 amp. I wired the subs posotive to posotive then jumpered to the terminal strip inside the box, I did the same for the negative, when I put a dvm on it read a little over 1 ohm about 1.3. is this correct? I thought I should get around 4 ohm when I go posotive no negative on the connections on the back of the box. according to some wiring diagrams I've seen it shows going posotive to negative on one set of coils and then the the terminal strip inside the box of the other set of coils, seemed odd to me to take the posotive to the negative. Can I ground the amp right off the batter or is that to long, if would be about 4 feet. Thanks in advance. Jesse. |
07-20-2010, 11:07 AM | #2 |
Drives: 2011 Camaro 2LT, RS, Sunroof, IBM Join Date: Jun 2010
Jesse, since your amp only has one mono output, wire each speaker in series then with the pair in parallel.
Ralph
Other current rides & toys:
1999 Civic 1999 GMC Suburban, 10" lift 2000 Ford Mustang GT conv. 1973 Kona Jetboat, 463 BB Olds "The Money Pit" 2007 Hi-Jumper sandrail powered by 2110 VW "Mexican Jumping Bean" 2008 Pace American 16x8 enclosed trailer with 600w Rockford system, ideal for tailgating & Pismo runs The first one that got away: 1973 Camaro LT 350 with custom T-tops |
07-20-2010, 11:46 AM | #3 |
Rhymin and Stealin
to get 4 ohms on each woofer you need to series the voice coils.
on each woofer... take the + of one side to the - of the other side then use the remaining + & - to the amp. If you parallel the two subs together your resitance load will be a 2ohm load.
Bryan
I Make Cars Sound Good. Enchantment Editions Arc Audio Competition Team Image Dynamics Elite Sound Performance Team Team Stinger |
07-21-2010, 08:16 AM | #4 |
Drives: 2010 Camaro B/B 2ss/rs A6 Join Date: Nov 2009
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Simply the best wiring diagram I have ever seen... I know you don't have fosgate, but that won't matter
Black on Black 2SS/RS A6 with Stage 2 mastmotorsports cam and Kooks headers/exhaust
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Nice seeing you guys last Saturday in SoCal! | MustMotoring.com | V8 Bolt-Ons & Tunes | 0 | 09-03-2009 04:33 PM |
Heres My Plan. Let me know what you guys think | 2010Camaro2LTRS | Member Car Journals | 29 | 08-12-2009 04:58 AM |
Hey guys, I've got a quick question about Credit Unions... | nUcLeArEnVoY | Camaro Price | Ordering | Tracking | Dealers Discussions | 1 | 07-09-2009 01:51 PM |
