03-14-2016, 09:37 PM | #1 |
IG @Brian_ _Self
Drives: 2010 Camaro 2SS M6+17'Tesla Model S Join Date: Nov 2012
Help me decide on what cam!
Okay, I've asked this before and I've come to a few choices that I seem to like.
1. SS3 GPI Cam 2. BTR Stage 4 3. Custom grind of 233/242 .629/.629 LSA:113+3 4. Custom Grind of 232/246 .646/.637 LSA:112 I'm looking for a choppy sound, along with as close to 500whp as possible. And something that plays well with 100-150 shot of nitrous. Which do you guys think would suit me best? Also in open to recommendations! And my biggest concern is the motor not blowing up, and if I have to sacrifice a few HP, so be it. This is a N/A build also. Leaning towards #1 or #2 mostly
03-14-2016, 09:41 PM | #2 |
IG @Brian_ _Self
Also a little bit of guidance on what makes a good Choppy tone would be appreciated if anyone can chime in
03-14-2016, 10:14 PM | #3 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Whichever you choose seems like youll have a good cam
03-14-2016, 10:26 PM | #4 |
IG @Brian_ _Self
Thanks man. Ive tried to look around a lot for what people are getting real world. These seem good I'm just see which ones are good, but still safe. Sent from my iPhone using Tapatalk
03-15-2016, 02:37 AM | #5 |
THE U
Drives: Camaro 1SS/RS Join Date: Jul 2015
I have a GPI SS2 VVT awaiting install. Great customer service and great results by others so far.
03-15-2016, 06:33 AM | #6 | |
Drives: 2010 Camaro RS/2SS Join Date: Sep 2015
My brother runs the BTR Stage 3 on his Z06 with a 200 shot perfectly fine. Getting ready to swap over to BTR Stage 5 for his car. The LSA on the custom grinds are too low for me and the lifts are way high for those power ranges.
2010 Camaro 2SS/RS M6
12.08 @ 115 - 9/2015 (392hp/393tq) NA w/ Exhaust + Tune 11/2015 (464hp/439tq) ^ + BTR Stage 4 w/ Halltech CAI Engine: BTR Stage 4 Cam; BTR Dual Spring Kit; C7R Chain; LS2 Tensioner; High Volume Oil Pump Drivetrain: ACT T2S-G05 x2 Disc XT Street Kit Exhaust: Kook's 1 7/8" Headers w/ Off-road pipes;Kook's 3" cat-back; QTP 3" cut-outs Suspension: BMR 1.4" Front & 1.5" Rear Springs; Blackdog Solid Mounts w/ Poly Bushings |
03-15-2016, 07:39 AM | #7 | |
Drives: 2014 SS 1LE Join Date: Apr 2014
03-15-2016, 08:15 AM | #8 |
Drives: Holden HSV Clubsport LS3 Join Date: Jan 2015
Why such a big cam? A small cammed LS3 will be a beat a those cams listed all day and every day on the street.
03-15-2016, 08:23 AM | #9 | |
IG @Brian_ _Self
Enlighten me? I have been mainly looking for cars who push 500whp and ask the owners for their specs. I haven't gone into breaking the numbers down as much as I would like to. I'm not gonna lie some of the numbers I done understand what they mean yet and what the differences between smaller and larger cams are. All I know is the 4 cams I listed people seem to be rather happy with their rusults Sent from my iPhone using Tapatalk
03-15-2016, 08:28 AM | #10 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
I'm just a shade tree with limited experience, but have found several really great threads on here explaining lobe separation angles, durations, lift and what these things really mean to you as the owner/driver. Hit that search button and read away!!
Good luck!
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
03-16-2016, 05:52 PM | #11 |
IG @Brian_ _Self
Called Texas Speed, got a 231/236 111 LSA stage 3 Cam from them.
I'll post a video after I get er all buttoned up Sent from my iPhone using Tapatalk
03-16-2016, 06:37 PM | #12 |
Drives: 2010 2SS/RS LS3 A6 IOM Join Date: May 2013
It's more than just duration numbers, what supporting mods?
There's a lot to be said about ramp rates and core material. |
03-16-2016, 08:24 PM | #13 | ||
Drives: ‘13 1LE Join Date: Jul 2013
Fast forward to 35 seconds If you are punching it stop sign to stop sign at legal speeds, then a smaller cam might be the way to go. |
03-16-2016, 08:27 PM | #14 | |
You will gain power, and thus, you can therefore spec out a smaller, milder, more engine friendly Low Lash cam, providing you with equivalent same power, of a larger, more radical, and therefore less friendly, hydraulic cam. |
