10-18-2019, 06:00 PM | #1 |
Drives: Black 1SS Join Date: Dec 2018
Need alignment help
Hi guys I’m currently at my local alignment shop and this is my 3rd time coming this week, after their alignment my steering wheel is slightly crooked for me to go straight I have to tilt it to the right slightly
These are the specs of the second alignment I’m not familiar with this kind of stuff and would really appreciate if someone who knows can chime in and let me know how the specs look thanks |
10-18-2019, 07:01 PM | #2 |
Drives: 2017 2SS / 2003 S10 Crew Cab Join Date: Oct 2019
The alignment looks ok except for the front toe setting. The left is -.10 and right is +.15 for a total toe of +.05..that means that when the car is going straight the steering wheel will be off to the right. If both front wheel settings are equal with the steering wheel aligned straight ahead and the total toe is within spec the steering should be close to center when driving. Note: it is not easy to get the steering wheel perfectly straight, there is a tolerance to have it a little off to either side when driving straight. Also the individual and total toe setting could in theory be within spec but the steering wheel still not straight if it is not perfectly aligned when making adjustments.
Never say never! |
10-18-2019, 09:45 PM | #3 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
Your front toe is 0.10* toe in on each side for a total of 0.20* toe in. Your Camber in the front is -0.95* on the left and -0.30* on the right. You have a 0.65* cross camber to the right. This will cause the vehicle to pull right. The vehicle will pull towards the most positive camber or most negative caster. Your caster is not adjustable. But the right side is more negative so that's the direction the vehicle will pull.
The rear toe and camber are the same measurement and you don't have any thrust issues so all is good. As for the steering wheel being offset, how far? Usually there is a spec for the degrees of offset. If it's less than 3* most manufacturers call it good. But to fix it you need to adjust the tie rod ends. If it is offset to the right to need to shorten the left tie rod and lengthen the right tie rod. That's how you fix the offset. After setting the alignment, the tech should have jounced the suspension and re done a caster sweep and check the settings. This is done to settle the suspension and make sure the settings are correct. BUT, most places wont do that. The get it in the green and send it.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
10-18-2019, 11:17 PM | #4 | |
They definitely improved it but this is the 3rd day of them adjusting it. When I actually hold the wheel straight it goes left slightly it’s better than before but still pulls slightly left when I hold the wheel straight. I’m becoming frustrated as the shop employees are starting to become rude because I keep going but I refuse to drive with a crooked wheel Last edited by Clos.95; 10-19-2019 at 12:09 AM. |
10-19-2019, 09:25 AM | #5 | |
Drives: gas powered Join Date: Jan 2019
Find another shop that can align your car with the wheel straight.
10-19-2019, 01:26 PM | #6 | |
one flat refers to the hex on the tie rod that is used to adjust the toe setting.It equals 1/6th of a revolution.
10-21-2019, 12:40 AM | #7 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
