09-27-2019, 09:17 PM | #1 |
Drives: 2018 Camaro SS Join Date: Feb 2018
Does 6MT Drain Plug Need Sealant?
I've scoured the forum and I've found 3 answers:
1. Yes, use GM part number 12346004 2. Yes, use threadlock blue 3. Yes, use threadlock red 4. No, it has teflon coating and can go back on after a simple clean So at best one of these is right, please help!! Thanks, Will |
09-29-2019, 10:03 PM | #2 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
I didn’t put anything on mine when I changed my fluid. It doesn’t leak.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
09-30-2019, 07:38 AM | #3 |
Same here.
09-30-2019, 07:56 AM | #4 |
Drives: Chevy Camaro Join Date: Jul 2019
Its a pipe plug no need for any sealant especially red loctite.
10-03-2019, 01:36 AM | #5 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
blue loctite will work if you want no chance of a leak. Transmission fluid is much less viscous than engine oil and it can work itself out between threads if the temp is high enough. Doubt it would ever be an issue but you never know, so I used blue loctite.
10-05-2019, 01:22 PM | #6 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
+1 on the blue loctite. Perhaps it didn't help, but it hasn't hurt either.
I'm sure GM part number 12346004 is the definitive answer- but who's got some of that laying around the garage? |
10-05-2019, 04:41 PM | #7 |
Drives: 2016 2SS Convertible Join Date: Oct 2017
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
10-20-2019, 03:39 AM | #8 |
Drives: like an old lady Join Date: Jun 2012
the same drain plug design has been employed for decades in trans and differentials both. no sealant needed.
10-20-2019, 07:17 AM | #9 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
None here either.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
10-28-2019, 08:04 AM | #10 | |
10-28-2019, 10:03 AM | #11 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I also didn't use anything. no leaks.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
10-28-2019, 09:27 PM | #12 | |
As far as needing to put sealant on the transmission plug threads, probably not since it is a pipe thread, but, I have always put a little sealer on these types of plugs. Old dog...new trick thing I suppose...
