09-12-2019, 07:05 PM | #15 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
09-13-2019, 09:31 AM | #16 |
Drives: 2013 C6Z06 Join Date: Nov 2016
It's actually 51psi and yeah I monitor it pretty closely, I've seen it get to 50...
09-15-2019, 09:28 PM | #17 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
From TireRack - A tire's maximum inflation pressure is the highest "cold" inflation pressure that the tire is designed to contain.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
09-16-2019, 07:05 AM | #18 | |
Thanks and cheers! |
09-16-2019, 09:07 AM | #19 | |
Yes, I was going to say that about GM's high speed pressure recommendation. |
10-06-2019, 11:05 AM | #20 |
Drives: 2019 ZL1 1LE Camaro A10 Join Date: Jun 2019
I run -3.2 camber and .125 toe on a pretty rough track 3.7 miles 17 corners and seems to be working pretty well - still shows a little more wear on the outside. If there cording inside it’s more than likely your not pushing quite hard enough. My experiences with the Hoosiers is if you get them much above 47-48 hot they will delaminate .
2019 ZL1 1LE
2016 Mustang GT 2014 GT 500 2012 GT 500 2010 Mustang Spec Iron 2003 New Edge w/Coyote Now running in America Iron 2000 New Edge w/ Coyote 2004 Corvette 2002 Corvette |
10-09-2019, 08:43 AM | #21 | |
10-09-2019, 08:11 PM | #22 | |
But cording the inside has nothing to do with not pushing hard enough. It has to do with the INSIDE tire scrubbing (as Sean has pointed out in another thread i believe). Or just too much camber. Or toe being out of whack. Or all of the above. |
10-10-2019, 11:20 PM | #23 |
Agreed - about 70% of miles put on are on the track.
2019 ZL1 1LE
10-11-2019, 01:36 PM | #24 |
Drives: 17 SW 1LE Join Date: Jun 2017
I got 40 sessions or 10 days out of my first set of fronts, so likely its a driving habit if you are killing SC3's in 3 days.
Just in the off chance you didnt know, it should be noted that as a whole an SC3 has 7/32" of tread depth. However on the outside 1/3 of the tire you get 4/32" worth of tread block and then 3/32 of solid rubber while the inside still has depth left. If you dont know this about the SC3 it can appear like it wears out real fast. |
