10-03-2019, 01:18 AM | #29 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
A bottle of ceramic coating costs $50 wholesale and will cover 2.5 cars.
A good paint correction should take 5-8 hours at $75/hr. It takes about an hour to apply the coating at $75/hr. So it should take 6-9 hours to perform a ceramic coating. That's how much I charge for a ceramic coating job. Ceramic is not magic. It is prone to get water spots if you have hard water. It will still get swirl scratches if you aren't vigilant with your wash methods and towels. It will give you a very slick surface for about a year. That very slick surface SHOULD allow you to wash less frequently and keep bugs and things from sticking as much as an uncoated surface.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
10-03-2019, 05:48 AM | #30 | |
Drives: 2018 ZL1 , 2020 GMC AT4 Carbon Pro Join Date: Apr 2019
That kind of touches on my theory. When people traditionally wax their cars, they don't spend several hours doing prep work and paint correction. IMHO, people discount the effects of all the extra work that goes into applying ceramics when they see the final product. It's just not the same as a clay bar and a coat of wax, and the results should obviously be better. However, I seriously doubt there would be a noticeable difference if the same prep work were done prior to applying a coat of wax. As far as there being this massive difference in protection, I personally have not seen it. I top my ceramics with Polish Angel Cosmic Spritz and I would say that bugs come off a little easier, but beyond that, I have had the same issues with dirt, dust, and bird droppings adhering to the surface. We have not seen rain here in over a month, so really the only thing accumulating on my paint is dust and pollen. Even hitting it with a pressure washer doesn't remove all of that. All that said, even though the Cosmic Spritz is expensive, it is by far the best maintenance coating/ polish I have used. |
10-03-2019, 07:42 AM | #31 | |
Just because you’re not seeing it personally, doesn’t mean that is normally the case...Think about it, a pressure washer is not removing dust & pollen?!? Crazy, since that shouldn’t be an issue for either wax or ceramic. It just sounds like you have some issues with your coating. Bad product, bad prep, who knows. But a proper ceramic coating will give *years* of protection. My buddy has the old last generation EXO (V3) ceramic on his ride. It’s been on for 2 years as a *daily driver* in New England...a serious test! I saw him pressure wash it a couple of weeks ago, still looks great, beading like crazy, and no mitt needed. Moral of the story: meticulous prep work plus fresh product will give you great results. It’s a bummer that didn’t happen for you.
10-03-2019, 09:58 AM | #32 | ||
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2019
10-03-2019, 12:48 PM | #33 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I go to a respected detailer and whether you get a ceramic "booster" or a good, clay bar/wax reapply, the costs are very similar. I would venture that the profit margins on ceramic related stuff is higher than non ceramic options.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
10-03-2019, 12:54 PM | #34 |
Drives: 2018 ZL1 A10 Join Date: Sep 2014
While I agree that the majority of the cost is in the labor/time, paint correction is NOT required before a coating is applied. With that being said, a coating only looks as good as the paint under it and I'd highly recommend correction and polishing prior to a coating. The paint surface should still be prepped prior to any coating - sio2, wax, etc or it'll fail prematurely.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
10-03-2019, 12:55 PM | #35 |
Gtechniq sells one of the best consumer-grade ceramic products on the market IMO. CSL topped with EXO is a solid combo.
10-03-2019, 02:26 PM | #36 |
This. Agree 100%.
10-04-2019, 05:57 AM | #37 | |
My point is that I believe ceramics are overhyped. Sure, the average ceramic coating is probably better than the average coat of wax, BUT it is also much more expensive and just as involved in terms of maintenance. All I can really say is that I've tried 3 different coatings and two different professional installers. I have been disappointed in the performance of ceramics compared to what I was led to believe by reading countless reviews and testimonials prior to having my vehicles coated. Trust me, I REALLY wanted to have my socks knocked off, but that just didn't happen. It's not that they're bad, it's just that there are products out there now that offer similar results for a lot less money. IMHO, if you think you're going to get a ceramic and walk away with a car you hardly have to work at to keep clean and shiny for years to come, you're sorely mistaken. There is still a lot of work involved to maintain the coating and the finish. If you are willing to put in the work and take pride in protecting your finish, a quality wax or spray will do just as well for a lot less money. Either way, it's an exciting time in the car care industry. There are lots of new and inexpensive products coming out that seem to be fantastic. |
10-04-2019, 10:38 AM | #38 | |||
10-04-2019, 12:46 PM | #39 | |
The thing is, however, it's so easy to overlook or minimize advantages once we secure them. I honestly don't touch the car most of the time, a "spray-off, foam, spray, foam, rinse, dry with a leaf blower" cyle practically cleans it up---for a year or so before the coating starts to give out a bit (I have Ceramic Pro on the Camaro). Obviously, wheels and tires and glass and plastic do need additional treatment, plus occasionally I have to break out the mitt and thus almost inevitably put minor scratches into the clear over time, yet whenever I wash my wife's SUV, I realize the difference again and again and no longer regret going with the ceramic.
10-05-2019, 05:23 AM | #40 | |
I will say that both my truck and car are black. Perhaps that is the difference between myself and others that say they can basically rinse dirt off without having to was it in a tradition manner. I think if I had white or silver, perhaps, my opinion would probably be different. |
10-05-2019, 10:54 AM | #41 | |
Personally, I have received calls in my 2 years of business where someone asks me to fix other detailers' mistakes. They're usually a failed coating due to improper prep. Also, my personal prep process is a bit redundant, but gets it done. I hit each panel separately right before it's coated. I first spray it down with Prep All, wipe with a microfiber, then spray it down again with Gyeon Prep and wipe with a separate microfiber. Overkill, but I know any polish left over has been completely removed and no weird spots missed.
10-05-2019, 10:58 AM | #42 | |
I'm also a bit obsessive about hand washing regularly. Quality coating add just enough hardness to help with damages caused by washing IMO. I use the two bucket method with microfiber mitts/pads and Dreadnaught drying towels with light pressure.
