Old 08-14-2019, 09:42 AM   #1
Aviadtz
Drives: 2017 Camaro 2SS 50th
SS tends to shift rough
Hey,
So I got myself a 17' ss with the A8, haven't had a really big issue with it other than it sometimes jerking the car a little bit during lower speed shifts, usually from 1-2 or 3-4.
I was advised from my dealership to do the triple flush, yet I fear switching the transmission oil will cause the shuddering other people get, is that a possibility or nothing to be worried about?
Car has about 20k miles on it.
Aviadtz is offline   Reply With Quote
Old 08-14-2019, 10:03 AM   #2
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
Originally Posted by Aviadtz View Post
Hey,
The new flush may fix it and will not cause the shudder.
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 08-14-2019, 04:26 PM   #3
njweatherman
Drives: 2018 Camaro 2SS, redline edition
The new flush will prevent you from getting the shudder down the road. I had the shudder recenty and the flush fixed it. However, I still have the rough 1-2 shift when the car is not warmed up yet.
njweatherman is offline   Reply With Quote
Old 08-14-2019, 05:06 PM   #4
Aviadtz
And after it warms up, does it fade? Since mine sometimes has it also when up to temps.
Old 08-29-2019, 08:16 PM   #5
JP2017SS
My car does this too, I had the flush 3k miles ago and it did fix the shutter. But the cold 1-2 shifts are really annoying me now. I’ve also noticed that even when the car is warm I’ll come to a stop sign and turn with light throttle then I will get this lagged hard shift that throws me forward. Doesn’t do it every time, but I’d say 25% of the time. Only way I’ve found to avoid these shifts is to shift manually but I feel like for what we paid we shouldn't have to put up with this. I’m going to schedule another visit to the dealer while I’m under warranty.
2017 Silver 2SS A8
JP2017SS is offline   Reply With Quote
Old 08-30-2019, 05:04 PM   #6
Aviadtz
An update that might help:
I did the flush and it did help quite a but with the rough shifts but didn't smooth it out completely, what I did find out is that when I use the Range AFM disabler the rough shifting stops for 99% of the time, I got no clue if it's related or not, but it is like that from me so..
Just a heads up that might help!
Old 08-31-2019, 12:17 AM   #7
JP2017SS
Thanks! I’ve read about it but was a little hesitant to try it out. I think I’m gonna give it a shot now!
2017 Silver 2SS A8
Old 09-03-2019, 10:24 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I would have the Trans adapts reset(Fast learn reset). perhaps the dealer didn't do this after changing the fluid.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 09-10-2019, 09:11 PM   #9
JP2017SS
Thanks, yeah im taking the car in to the dealer in a couple days for the power steering recall fix and to address the shift issue. I will ask for the reset as well. The range device didnt help with the 1-2 shifts, but it did make the car feel a lot smoother overall. I'll put it back in after the visit to the dealer.
2017 Silver 2SS A8
Old 09-16-2019, 12:24 PM   #10
john703
The new transmission fluid didn't really help my harsh 1-2 shift, but interestingly, shift smoothness improved significantly after I installed a ported throttle body. Of course throttle response improved as well, so that's a mod I heartily recommend.
2017 Camaro 2SS, Mosaic Black, A8
john703 is offline   Reply With Quote
