Old 09-05-2019, 04:28 PM   #15
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Originally Posted by Paro View Post
What was the runout on the newly installed rotors?
I didn’t know enough to ask. They replaced my rotors, with a senior mechanic supervising that everything was done to spec. It’s been a few weeks now and all is back to normal. Hope it doesn’t return!
Ah...disregard...I see you were asking someone else in this thread.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 09-07-2019, 01:08 PM   #16
fighting irish
The Doctor is in
fighting irish's Avatar
Drives: 2016 Camaro 2SS Nightfall MRC NPP
So I finally got around to measuring runout at the hub and on the rotors. .010” at the hub and .012” at the edge of the rotor on the front driver side. This was on a new rotor after cleaning the hub completely. I’m thinking that the runout at the hub is causing excessive disc thinkness variation resulting in the brake pulsations. What would the fix be? Hub replacement? Shims? I autocross so a shim isn’t sounding like a good solution.
Conversely on the passenger side it was about 0.005” at the edge of the rotor, so I didn’t replace it yet.
2016 2SS MRC NPP Sunroof Nav, Forgestars CF5V with RE-71r 275/35r19s in front and 285/35r19s in rear
2017 Silverado 1500 LT Z71 Double Cab
2017 Honda Pilot Elite
fighting irish is offline   Reply With Quote
Old 09-12-2019, 10:53 AM   #17
superdave 72
Drives: 2018 Camaro SS 2SS Garnet Red
Brake Issues
I had the SAME issue with shaking at tip-in of brakes. Dealer had it for TWO friggen days without doing anything to it and said it was my fault for spraying tire cleaner on tires. Said it soaked the pads and warped the rotors. Got it back this morning, after refusing to pay them $975 dollars to replace all four sets of pads and turn rotors.
Went to a Muscle Car shop that I have used a couple of times for my 3.8 Genesis Coupe and my 2014 Mustang GT. He said it was because of the large buildup of brake dust on the pads and rotor that is causing Pad Hop, because of the buildup. I ordered a set of Powerstop Extreme z26 Carbon Ceramic pads for the front and he will install them on Saturday and turn the rotors. Total coast of pads, turning, and labor, probably UNDER $200. Saved ONLY $800...SHEEEESH! Will let y'all know how it works out.
superdave 72 is offline   Reply With Quote
Old 09-12-2019, 01:06 PM   #18
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
You can warp a rotor if you don't torque the wheels correctly.
ssmofo is offline   Reply With Quote
Old 10-19-2019, 07:33 AM   #19
gmcvt
gmcvt's Avatar
Drives: 2019 Camaro 1SS A10
One possible thought/solution on the hub/rotor runout issue might be using an on car brake lathe. I work for a Honda dealership and for the front wheel drive applications Honda says to cut rotors with an on car brake lathe. It accounts for hub runout.. I had a similar issue as the OP with my Accord and the techs were using the OFF car lathe in our shop. The third time they used the ON car lathe and the problem never came back. There are some lathes that are self powered (meaning that the lathe itself turns the rotor) and others use the engine to spin them. Obviously we would need the former.
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6
2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD**
2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD*
2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD*
gmcvt is offline   Reply With Quote
Old 10-19-2019, 08:32 AM   #20
TJay74
You are not actually "warping" a rotor by not torquing the wheels correctly. You are only distorting the rotor.
Also with how thick the rotors are and the hat is, I highly doubt anyone is distorting a rotor on a newer Camaro from torquing the wheels incorrectly.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
