12-04-2022, 11:44 AM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
SG3 part number breakdown
Guys,
Below are the individual part numbers for the struts that are part of the SG3 suspension package. The ORIGINAL part number on this package was SG3 Suspension (84203549 from www.sdparts.com – cost 1816.09 Note: NEW PART NUMBER is 86773565. I have been asked about this in case someone needed to replace one of the struts that were part of this package, and it just so happens upon inspection THIS WEEK I found that it's time to replace mine. NONE of the part numbers on the struts themselves will pull up as valid part numbers in the GM system. SO here you go. The MATCHED springs in this kit I will have the part numbers for those NEXT week. Front Driver's STRUT is 84004134 Passenger side STRUT is 84004135 Rear shock Absorbers are BOTH 23334341 You need to remember these are SPECIAL ORDER parts and take a minimum of 5-7 days to get to you assuming they are in stock. As in the case with most of GM parts these parts are supplied by an outside vendor
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 01-22-2023 at 10:56 AM. |
01-22-2023, 10:52 AM | #2 |
UPDATE to Part Numbers
OK guys I got the part number for the SPRINGS that are included in the SG3 suspesnsion package.
By the way, since I installed my coilovers, I am selling my SG3 suspension with the exception of the front struts that were worn out. I have this listed in the MEMBER for sale section under SUSPENSION. https://www.camaro6.com/forums/showt...2#post11275052 Here they are : 84404137 are the FRONT springs 84004133 are the REAR springs (these are NOW showing DISCONTINUED)
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 01-22-2023 at 11:24 AM. |
Thread Tools | |
