11-26-2022, 11:10 PM | #1 |
Borla secondary Cat delete forward pipes
Im looking for the Borla secondary cat delete pipes for a 16 camaro ss. I cant find any for sale anywhere. Borla discontinued these pipes on the new Cat-back exhausts. The part numbers for the forward pipes im looking for is 55940 & 55941. If anyone has these laying around or knows someone willing to part ways with them id definitely love to buy them. I attached a picture of what the pipes look like.
11-27-2022, 08:27 AM | #2 |
Drives: 23 2SS 1LE Join Date: Feb 2019
If you want the cats deleted and are taking it to a shop, just have the shop weld in pipe on their own. No need to overpay for pipe from Borla.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
11-27-2022, 08:52 AM | #3 |
Must be a slow day at the EPA. Guy with 2 posts chimes in looking for cat delete pipes…
11-27-2022, 11:09 AM | #4 |
It’s not going to a shop. I want these pipes cause they’ll connect to the borla xpipe/midpipe I’ll be getting eventually. The new xpipe/midpipe installation requires cutting just behind the secondary cats and I’d rather avoid that. The cat delete pipes are only $200 ish.
11-27-2022, 02:07 PM | #5 |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
Good luck. I spent hours looking for these just yesterday. Apparently the EPA came down on the aftermarket for making them. Also beware, lots of scammers looking for WTB posts.
11-28-2022, 10:21 AM | #6 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Ya the EPA clipped manufactures that had the 2d cat delete pipes, or "link" pipes AWE called theirs.
11-30-2022, 01:04 PM | #7 |
Drives: 2020 Camaro 1SS M6, Ford Fiesta ST Join Date: Mar 2020
Take a look at MRT exhaust. It looks like their catbacks have the piece you need. They might sell that separately if you ask. IF it will fit the exhaust you want to use.
11-30-2022, 05:14 PM | #8 |
Thank you ill check it out!
