11-12-2022, 12:29 AM | #1 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
HOW TO TURN ON INTERCOOLER PUMP WITH HP TUNERS???
Hey team, my car is back together, and I am almost ready for first start up, but I want to turn on the intercooler pump so that I could fill and bleed the system. I was told there is a button to do this within HP tuners, under the engine area but I can’t find it. Can someone point me in the right direction?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
11-12-2022, 10:02 AM | #2 |
Thank you Al Oppenheiser!
Just jumper-feed it 12v directlty.
But yeah I can see why you'd want to control it and more important see status running or not and any cavitation faults, etc. I have no clue if any of these generic states are available in HPT, but according to this post there is a way. |
11-12-2022, 02:58 PM | #3 |
Thanks Gunk, I could not find it, and just ended up bypassing the relay with a jumper wire... worked fine, but damn it was messy to fill and bleed.
11-14-2022, 01:04 PM | #4 |
Petro-sexual
If you go into the SCANNER, put the car in ACCESSORY mode, go to VEHICLE CONTROLS & SPECIAL FUNCTIONS, then go under the ENGINE tab (I think), and poke around under the sub-folders to find the INTERCOOLER pump switch. It will turn-off, though, until there is enough coolant to keep the pump loaded, so sometimes bleeding is a beesh, because you have to keep turning it off-then-on-etc., lol.
Thread Tools | |
