11-05-2022, 04:57 PM | #1 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Updated throttle house times
Four GM vehicles still in the top 10, two of which are Camaros.
11-05-2022, 07:11 PM | #2 |
...and the ZR1 is actually still #4, they messed up the ordering (the BMW M4 CSL in their most recent test was slower).
11-05-2022, 07:40 PM | #3 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
That car is 2.5 seconds faster than a zl1 1le around their track, and barely slower than a zr1 with 200hp more. I know it’s $140,000 but that’s damn impressive. Those bimmer horsepower must be measured in Clydesdales
11-05-2022, 07:57 PM | #4 |
Wouldn’t be surprised if that car is actually closer to 600hp.
11-05-2022, 07:57 PM | #5 | |
Drives: Ferrari F40 Join Date: Sep 2022
https://www.roadandtrack.com/news/a3...nd-m4s-473-hp/ https://www.bmwblog.com/2012/09/10/d...ated-527-rwhp/ https://www.carscoops.com/2019/10/bm...an-advertised/ https://www.armmotorsports.com/blogs...k-dyno-results |
11-06-2022, 01:15 AM | #6 |
Drives: 2022 2SS 1LE Join Date: Dec 2021
I am confused why the ZL1 and the SS are so close in times. I know that they have a small track but you'd think that the ZL1 would be at least a second or two faster than the SS.
11-06-2022, 02:39 AM | #7 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Impressive to see the SS 1LE ranked above the GT500!
Mosaic black 2018 Camaro 2SS A8 (sold) |
11-06-2022, 07:24 AM | #8 |
Drives: 2SS 1LE M6, Palisade Calligraphy Join Date: Nov 2021
There are no long straights and ss 1le has a better overall balance with lighter weight and good weight distribution. I want them to do a track comparison of Mach 1 manual vs Camaro ss 1le manual or both auto on the same Cup2 tires. Same as GT350TP, I don’t think Ford is allowing that. We only saw the PP2 vs 1le so far same day same tire comparison. Randy’s test doesn’t count because the 1le had brake issues with many miles on it, auto vs manual.
11-06-2022, 07:27 AM | #9 |
Lexus RCF track edition even costs around $100,000! Performance per dollar value is at minimum
11-06-2022, 08:19 AM | #10 | |
Gt500 placing is also surprising. |
11-06-2022, 02:27 PM | #11 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
I am a regular Throttle House watcher; big fan of them...that said:
The ZL1 1LE was ran ~3 years ago and was an M6. They have recently said the track is faster now than it used to be. Less green, so to speak. If they were able to test it again this season, it would get a better time. They also said the ZL1 1LE was in its stiffest suspension setting, and they have a bumpy track, so it wasn't able to put the power down as early as it should have. It would have been faster in a softer damper setting. Also, there's very few straights, so the power difference didn't help it much over the slightly lighter weight SS 1LE. Same story w/ the base GT500 they tested, which was on Michelin PS4S tires, nowhere to stretch its legs, so to speak. I wish they'd test a regular ZL1, I'd bet it would be quicker than their ZLE's time because: a) more compliant suspension, and b) more recent Throttle House lap times have been faster than older tests. It's also possible Thomas is a better driver now, 3 years later - he's done a lot of racing since then. I bet it would be in the 1:10s, about as fast as the M2 CS, I'm guessing. Also, they ran an SS 1LE on Cup 2 a few years ago, and more recently ran an SS 1LE on OEM Goodyear SC3 tires. The Cup 2 time was only 0.04 sec faster than the OEM Goodyear SC3 tires, which ran a 1:11.62. That isn't on this list for some reason. It's also missing the PP1 GT w/out MagneRide from a couple of years ago, which I think was in the mid 1:14s IIRC. The Supra was pretty impressive, barely behind the SS 1LE and GT500. I also have a '22 Supra 3.0 in addition to my '21 ZL1, so I'm glad to see the Supra do well. I can say from experience it is a very responsive handling car and almost exactly as quick in a straight line as an automatic 6th gen SS. The Supra's 3,350 lbs weight with 52/48 front/rear weight distribution (compared to ~3,900 lbs and 54/46 on my ZL1) is noticeable over my ZL1. The front end feels lighter, for sure.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 Last edited by Idaho2018GTPremium; 11-06-2022 at 02:38 PM. |
11-07-2022, 07:48 AM | #12 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
11-07-2022, 07:59 AM | #13 | |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
I don't recall the DSSV dampers in the ZL1 1LE being adjustable, even manually? Nigel |
11-07-2022, 08:14 AM | #14 |
Drives: 2018 Audi TT RS Join Date: Jan 2014
I know a couple of people here already mentioned it but, general rule of thumb when looking at BMW stock BHP figures is to just immediately convert that to WHP, instead. If you see a BMW listed with 540bhp, expect that it makes around 540whp, 605bhp = 605whp, etc., etc. They also tend to size their turbos in a way that gives them monstrous torque. This is largely why Supra's are much quicker than their numbers imply. Not only do they weigh very little, but coupled with the aforementioned factors, they're actually much more powerful than their metrics lead you to believe.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
