10-28-2022, 10:17 AM | #1 |
Drives: Camaro RS Join Date: Oct 2022
RS tire question
New guy here with a question on tire fitment. Have researched and really not found a clear answer. I have a 2018 RS and would like to go with a little wider tire on the stock wheels. Should I go with a 255 35 r20 or a 265 35 r20? Not tracking but would just like a wider tire on all 4. Thanks.
10-28-2022, 11:41 AM | #2 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
You need a 9" wide wheel for 265. Just look on tire rack.
10-28-2022, 12:24 PM | #3 |
Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
If it is overall grip you are looking to improve, I would also consider keeping the tire size the same and changing the tire type. Going with something like a Pilot Sport 4S would improve grip better than moving to a 265 all season.
10-30-2022, 07:00 PM | #4 |
Drives: Chevy camaro Join Date: Jan 2022
He asked a question and said that he just wanted wider tires. Not different wheels or better grip.
I'm also curious what is the widest tire that can be run a 20x8.5 wheel? Or what other tires can be run on that rim?
Glenn
2017 Camaro 2LT RS Convertible |
10-30-2022, 07:23 PM | #5 |
Found this: https://wheelssize.com/wheels/20x8.5/
Recommended tire sizes for a 20x8.5 rim This table helps you to find the best tire size for your 20x8.5 rim because it collects the real users' experience from the car forums and wheel manufacturers (the data is taken from their galleries). Tire size Wheel diameter Popularity LT 35/11.5 R20 20.3" 1% P 225/25 R20 24.4" 1% P 225/30 R20 25.3" 5% P 275/25 R20 25.4" 1% P 235/30 R20 25.6" 10% P 245/30 R20 25.8" 16% P 255/30 R20 26.0" 3% P 225/35 R20 26.2" 13% P 265/30 R20 26.3" 1% P 275/30 R20 26.5" 1% P 235/35 R20 26.5" 6% P 285/30 R20 26.7" 1% P 245/35 R20 26.8" 21% P 255/35 R20 27.0" 8% P 265/35 R20 27.3" 1% P 275/35 R20 27.6" 1% P 240/40 R20 27.6" 1% P 245/40 R20 27.7" 2% P 285/35 R20 27.9" 1% P 335/30 R20 27.9" 1% P 255/40 R20 28.0" 2% P 225/45 R20 28.0" 1% P 265/40 R20 28.4" 1% P 240/45 R20 28.5" 1% P 275/40 R20 28.7" 1% P 245/45 R20 28.7" 6% P 255/45 R20 29.0" 6% P 245/50 R20 29.7" 1% P 275/45 R20 29.7" 1% P 255/50 R20 30.0" 1% P 265/50 R20 30.4" 1% P 275/55 R20 31.9" 1% LT 285/55 R20 32.3" 1% LT 305/55 R20 33.2" 1% LT 295/60 R20 33.9" 1% LT 275/65 R20 34.1" 1% As you see this is the biggest tire you can put on a 20x8.5" rim. What is the widest tire for 20x8.5" rim? Recommended P tire sizes that fit 20x8.5 rim % Width 30 35 40 45 50 55 60 225 65 235 50 245 78 104 9 28 255 15 37 6 28 1 265 2 275 3 2 285 305
Glenn
10-30-2022, 07:32 PM | #6 |
Drives: LT1 Join Date: Mar 2022
https://www.camaro6.com/forums/showt...=610690&page=2
Post #23 is interesting. I would like to see how it works. |
10-30-2022, 08:09 PM | #7 |
Thanks to everyone on the information!
11-01-2022, 07:27 PM | #8 | |
Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
https://www.camaro6.com/forums/showp...04&postcount=6
Previously Owned:
2018 Silver Ice Metallic Camaro R/S 1992 Dark Teal Camaro R/S 305 V8 |
Thread Tools | |
