10-20-2022, 01:47 PM | #29 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
This is all good dialog information, we need to be aware of. Let's just talk a daily driver , our 2022 Blazer LS , front wheel drive, it's a road transportation vehicle, if the engine light comes on likely the problem is covered. Hard / spirited driving will never happen , so likely abuse will not be a factor not to warrant the repair. Now my ZL1 is a fun spirited driving Car , not a track car( I won't rule out a track day with the Camaro Club) but there is a difference between the two vehicles in this post . If a half shaft fails or the torque tube on track day or spirited driving thru the canyon's and the Dealership contends abuse, I'll try to plead my case, but if they refuse,I suppose it's on my buck. Now a water pump , alternator, electronic steering, or engine component fails, (with no evidence of low oil level) I can't see that would consider being abuse
Warranty on a Performance Car, most likely has a gray area up to the Chevrolet or GM Dealership the owner frequents. I'm a retired Technical Engineer and analize every angle of a situation. Happy Motoring
2023 ZL1 A10 Shadow Gray Metallic
10-20-2022, 02:00 PM | #30 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
You are very adamant on proving us....scratch that, me wrong while I'm just letting you know the stories of good and bad experiences out there. But I see you believe Hagerty is a better source that what I posted about Al O was quoted saying. Your username has nothing to do with your reply's other than you are expecting to not get your car covered under warranty if you ever take your car to the track. Just let this die and you do what you want but don't try to feed information to people who have had stuff covered under warranty while on the track. It's like I've been preaching, it's all about the dealer you go to. Some will work with you but most only want to get out of warranty work to charge the customer way, way more than what they'll get from manufacturer. |
10-20-2022, 03:12 PM | #31 | |
Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R Join Date: Aug 2022
So doesn't that actually confirm what Al O said? And I never stated I was expecting to not get covered for track use.. Go ahead and try to find where I said that. Seems you are upset that I did my own research on it, but thats because I was trying to find it in the written warranty, which anyone with common sense would do. I mean, I would like a better answer for a clueless GM service worker than "Check out this Al O interview" or pointing to your Camaro 6 posts on the matter.
2018 Dodge Demon #1399 2020 Jeep Gladiator Rubicon 6 speed manual 2023 ZL1 1LE 6 speed manual ************************* 2018 Suzuki GSXR 1000R 2021 Kawasaki ZX10R Last edited by HemiDave; 10-20-2022 at 04:32 PM. |
10-20-2022, 03:27 PM | #32 | ||
So you admitting you wouldn't tell a dealer that this happened on track isn't your way of saying that you won't think it'll be covered under warranty? |
10-20-2022, 03:34 PM | #33 | |
Now if I got towed in from the track thats an entirely different story
2018 Dodge Demon #1399 2020 Jeep Gladiator Rubicon 6 speed manual 2023 ZL1 1LE 6 speed manual ************************* 2018 Suzuki GSXR 1000R 2021 Kawasaki ZX10R |
11-25-2022, 02:14 PM | #34 |
Drives: 2022 ZL1 1LE Join Date: Apr 2022
Didn’t want to have to bring this thread back to life but here I am. Dealer replaced knock sensors. Got me some new tires and alignment and went to the track today, figured all good. 4 laps in light comes on again, same as before. Stuttering at high rpm’s not sure if ecu cutting power or missing shifts. Either way I feel defeated. Dropped the car off at the dealer right away and told them to run every test they can so next time im on track there’s zero chance of getting the light on again.
Anyone know what the hell it could be? |
11-25-2022, 03:12 PM | #35 |
It's your thread, and good information you are communicating, sorry your still having issues, or maybe another code , bottom line that's what this forum is for , to share good times and hiccups .Keep up posted on your Car. Thanks again.
11-25-2022, 08:21 PM | #36 |
could be an air pocket in the intercooler circuit causing power loss due to high MAT/IAT3 temps. When the ECU sees temps above a threshold temp it will abruptly cut power.
11-25-2022, 08:55 PM | #37 |
Pardon my ignorance. I believe the Intercooler loop is connected to the main cooling loop correct? I ask because my problems began after a track session where some freak shit happened and a coolant drain hose broke. Dealer fixed it all and refilled coolant, but them not finding a bubble in there wouldn’t be the wildest thing. See pic
11-25-2022, 09:50 PM | #38 | |
11-25-2022, 09:54 PM | #39 | |
11-26-2022, 07:59 AM | #40 | |
I’m gonna wait to see what the techs say, will advise. |
11-26-2022, 09:37 AM | #41 | |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
edit: I just checked my car and that hose DEFINITELY connects to that broken off nipple. It goes up to the expansion tank. You've probably got a bunch of air pockets in the cooling system and it's over-heating in spikes and telling the ECU to cut power.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
11-26-2022, 02:19 PM | #42 | |
