08-24-2022, 02:40 PM | #1 |
Drives: 17 Camaro lt, 22 Camaro LT1 Join Date: Nov 2016
Are Lt1 Brembos bigger?
Trying to get a set of track pads for my 22 Lt1 camaro and it seems I can't find the right set of pads for the car. Here, these brembos are physically bigger and don't have the removable pins for quick changing pads. Bought a set of ebc yellow pads from phastek for a 16-21SS non 1le camaro and the pads are physically different and don't line up. Anyone know what pads these Lt1 cars take?
https://imgur.com/a/h9QsjBx |
08-24-2022, 04:10 PM | #2 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
08-24-2022, 06:30 PM | #3 |
08-24-2022, 07:18 PM | #4 |
Then they are the wrong pads, the LT1 and SS (non-1LE) have the same front 4 piston calipers... That yellow/pink pad almost looks like the SS rear pads (smaller 4 piston Brembos), your LT1 has single piston rears...
08-24-2022, 07:33 PM | #5 | |
OP, I haven’t seen anyone replace their brembo LT1 pads as of yet. So, I don’t have a good answer for you. |
08-24-2022, 07:55 PM | #6 | |||
I'd find it hard to believe that they would source yet another part just for LT1's...
08-24-2022, 09:05 PM | #7 | |
As an owner of three different Camaro’s, I can physically see some of the the design aspects are different from the SS and the Zl1. Namely, the hardware. The LT1 front brakes are brembos, it’s possible that the parts are from the Corvette or Cadillac line up. A cursory search backs this up… https://www.camaro6.com/forums/showthread.php?t=587671 |
08-25-2022, 12:34 AM | #8 | |
08-25-2022, 09:02 AM | #9 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Excessive copper killed the original front Brembo's in CA and Washington state for 2021. Chevy had to make the front calipers bigger to make up for the lost "bite" due to the compound change. I guess the aftermarket hasn't caught up yet.
Read here: https://www.caranddriver.com/news/a3...ia-washington/ OP, short answer is "yes". |
08-25-2022, 09:09 AM | #10 |
Drives: 2022 LT1, 1981 320i Join Date: May 2022
Could the confusion be over the copper free brakes? I think those are bigger than the copper one and I know people have issues with those. LMK what you find out. I have a feeling I will run into the same issue on my 22 LT1 w/ copper free brakes.
08-25-2022, 11:51 AM | #11 | |
If you’re going to give advice to guy that’s in need of solid info, you’d best know what you’re talking about first. That’s the point. Last edited by Chutzpah; 08-25-2022 at 12:12 PM. |
08-26-2022, 11:03 PM | #12 | |
You are right sir. I had to really dig but I found a thread from last year detailing the Corvette c8 with the z51 package brakes being installed due to California restrictions. Everywhere I look they list the SS and LT1 cars as having the same pads but the brakes are definitely different. The tell tale sign of the z51 brakes are the torx bolts that hold the brakes in. Really annoying because you have to remove the whole caliper to change pads. Thanks for the help guys. I thought I was going crazy there for about a week trying to figure out these brakes. Much appreciated! |
08-28-2022, 07:49 PM | #13 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
track down your RPO brake code and order the pads by the RPO code. If you want track pads call G Loc, measure the backing plate and the RPO code and they will make a set for you.
10-01-2022, 07:51 PM | #14 |
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
I have a 2022 LT1, and the same problem as the OP. I called PowerStop, they aren't aware of the change. So I ordered what they said, and I'll take pics and send it out to them. Hopefully they update their cross ref.... and I hope it spurs them to get some pads for our 22/23 cars.
I also ordered the rear pads, but they haven't come in yet. Hope they just work, or I'll be doing the same for the rears. Update... went and looked at the vette z51, looks about right. Did the OP get this resolved? Looks like PowerStop has a set for that application. Last edited by fj5gtx; 10-01-2022 at 08:25 PM. Reason: more research... |
