06-30-2022, 07:23 AM | #1 |
2016 2SS Convertible
Top stuck up/ trunk stuck closed
Had the 2016 SS convertible for about a week. Took it out Tuesday to a car show. I threw a bag in the trunk because I left the top down. Nothing big, size of a grocery bag. When I got home, I put the top up. Tried to open the trunk, no go. Tried the remote, the key fob and the door button... all no good. I tried to put the top down; I got the only manual method message. So, I figured the bag had somehow moved the partition. But why wouldn't the trunk open? Was attempting to use the emergency key slot behind the rear seat (pain in the butt) and decided to back down the driveway and break hard, hoping to move the bag. Sure enough, top goes down and trunk opens again. I get the top, although the partition looked fine and didn't have to be adjusted. But what is up with the trunk not opening? Had my 2011 for 2 years and never a problem putting stuff in the trunk!
06-30-2022, 02:50 PM | #2 |
Drives: 2016 1LT 'Vert Join Date: Feb 2022
Do an internet search for the Technical Service Bulletin #16-NA-257. This addresses Top Not Secure messages and Rear compartment lid not opening.
Depending on the vehicle's actual build date, it may need the folding top's latch re-balanced and the top controller re programmed. |
07-01-2022, 08:35 AM | #3 |
Hot Camaro
If the top isn't closed and secured, it's "open". And since "open" could mean a variety of things, including the tonneau being in a position where the trunk lid could strike it and cause damage, the trunk is disabled unless the top is fully closed and secured.
08-06-2022, 01:25 PM | #4 |
Drives: 2018 Camaro ZL1 Convertible Join Date: Aug 2022
only manual operation of top possible
I'm not trying to hijack the thread but I have many issues with the top also and the TSB I read might apply to my convert too. People here know way more than me. I bought a 2018 ZL1 convert with 1500 miles on it two weeks ago. The first time I tried to open the top I got the only manual operation message. I've got a 12 month gm warranty and have an appointment at a dealership next week. I've got a friend with a 2020 SS and he tells me the window retracts a little when he exits and then closes when he closes the door. I'm thinking my ZL1 should do that too but my window glass hooks on the top and snaps free when you open the door far enough. I'm thinking it is all part of the convertible top problem? After I checked fuses that were in the trunk fuse block I couldn't open the trunk without the key and lock in the back seat.
I get the top not secure message sometimes and another message tells me to open and close the drivers window. I do that and the message to do it returns repeatedly. I'm in SW Florida when I swapped my Yukon Denali for the Camaro and drove it home the first thing I noticed was the battery tender was set on top the battery and the line cord was caught in the convertible mechanism near the battery. I'm a retired EE and since I couldn't get the cord out I cut the plug off and then reinstalled it. The cord pulled free and I don't think it bent the mechanism. This could have caused the latch mechanism misalignment but not sure. I'll report back after the dealer finds and fixes the problem. Thanks for the info on the TSB. Never had a convertible before but have owned many muscle cars since the 60's. I had a 50th anniversary z06 vette for about 12 years. I'm an old gearhead ;-) |
08-06-2022, 01:35 PM | #5 | |
Hot Camaro
08-06-2022, 03:11 PM | #6 |
Thanks ember,
I did the programming and it seems to work. I had the car running on the driveway and the first time I got out it opened a small amount maybe a quarter inch or a little more. When I opened the door a second time to get in the window dropped about and inch. It didn't close by itself from there. I used the switch to close it. Not sure if it is supposed to. Drove the car a couple of miles to see if there was any difference in the top not secure message but I don't think there was. I cleared the messages and then noticed a chime 4 times every so often and then 8 or more times. I suspect I would have gotten the top not secure message. Before that I took a 6mm allen wrench and ran clockwise until it stopped and then counterclockwise until stopped. Then one more time clockwise until the stop and left it there. No change in messages and trunk still won't open. Maybe as the TSB says you have to reprogram the top controller along with adjusting the latching mechanism. |
08-06-2022, 03:20 PM | #7 |
Hot Camaro
The window should drop around 1/4" or so when the door is opened, and then go back up after it's closed. The message about the top "shouldn't" be related to the window indexing.
08-06-2022, 04:24 PM | #8 |
Two things I noted with all of my Camaro’s (3 in total, 2016-2022), the rubber trunk stops were set wrong (too high). Try unlocking your trunk, push down on the trunk, then try to unlock again. There’s a decent chance it will release (if that’s the problem).
As far as the window(s) clipping the convertible top…well, neither of the 2 convertibles did that when brand spanking new (top must have stretched some). After a few ups and downs of the top(s), the windows would clip the top, when opening the doors. It seems the speed in which I opened the door was quicker than the remote index activation. So, what I ended up doing is pulling the handle to the door open (to unlatch/ index) pause, then pull the door open. If you unlatch and pull at the same time, there’s a better than good chance you’ll clip the top. At least that’s my experience, on both convertibles. |
08-06-2022, 04:43 PM | #9 | |
Hot Camaro
In other words, I feel like the indexing is more important for closing the door than for opening it. |
08-06-2022, 05:58 PM | #10 | |
And personally, I don’t think it’s a negligible issue when the door gets opened and closed thousands of times (in its life) flexing the window and rubbing the top every time. It really annoyed me… that’s why I went through the effort to avoid it by slowing the door opening process. Sometimes I forgot, but it is what it is… now I don’t have that worry anymore! |
08-06-2022, 06:29 PM | #11 | |
Hot Camaro
If indexing is working correctly, then it shouldn't hit in either direction. If the drop is a little slow and it bumps a little while opening, it would at least be dropped down until it gets closed and there should be no impact in that direction at least. |
08-06-2022, 07:52 PM | #12 | |
The indexing worked just fine on my cars… so of course…it always closed perfectly. |
08-07-2022, 07:59 AM | #13 | |
Hot Camaro
To close the door, I had to press the glass toward the interior of the door to cause the height of it to be a little lower so that I could get it under the edge of the top. |
08-07-2022, 11:01 AM | #14 | ||
Thank you Al Oppenheiser!
