05-14-2022, 11:38 AM | #1 |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
Side Skirts Rocker Panels
WE just did a road trip from Il. to Wy. which is no problem for our 2022 RS vert. the problem is in Iowa our side skirt rocker panel left us at only 70 MPH. It sounds like hitting the rumble strips. So, we didn't know it till a Gas stop. Well, we keep going on to Nebraska the speed is up to 80 MPH and pass a semi of comes the driver side panel. The problem is they get destroyed and with the truck full no place to put them. What I kind of like to know has this happen to other people with the Side skirts??? This is only a 6 cyl. what about the big motor cars?? Monday it's down to Chevy to see about our warrant for parts leaving a car.. Yes it was fun only had to run 500 Miles a day then sight see.
05-14-2022, 12:37 PM | #2 |
Drives: 2016 SS 2SS Join Date: Jun 2021
How did you secure them to the car? Since they're coming loose was it just double-sided tape?
05-14-2022, 12:46 PM | #3 |
17’ Hyper Blue 2SS
Did you not pop rivets in them?
05-14-2022, 01:28 PM | #4 |
Yup, that's the pertinent question. Rivets or at least self-tapping screws are must, tens of them, otherwise forces will eventually tear off the skirt (if accidentally stepping on them doesn't first).
05-14-2022, 01:46 PM | #5 |
These are right from the Factory order. They were installed right the Chevy plant. It's all part of the RS package. I saw the 2-sided tape after they departed, I know you people have more miles than me. I've got all of 3,000 Mile on it that's why we did a road trip. I just figure the SS/RS have to go faster than 80 MPH and don't lose the rocker panels. The next set will be screwed on in the front, so they won't work lose. Thanks, for all the help.
05-14-2022, 02:55 PM | #6 | |
Love my Satin Steel LT-1!
Drives: 6-Speed LT-1... Join Date: Aug 2016
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels Technology Pkg|NPP|Satin Blk Pkg ZL1 Rock Guards|Red Knee Pad Set PBC LT1 engine built by Debi Lewis |
05-14-2022, 06:22 PM | #7 | |
I suspect this may have been caused by installer error, since this is an LPO (dealer installed) option.
05-14-2022, 07:06 PM | #8 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
05-15-2022, 12:32 AM | #9 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
I checked the box for them when I ordered it and had mine worked on 4 times (including the original install prior to taking delivery), as well as visiting 2 dealerships, and tons of calls to GM customer service to get them installed correctly. They were literally ill fitting/loose/falling off the car when I took delivery. I guess some corporate big wig finally got tired of hearing from me and dropped the hammer on the installing dealer. The service director that oversees the garage and body shop personally called me and was my service advisor. Very nice guy (car guy too) and he went above and beyond to get it all straightened out.
05-15-2022, 12:57 PM | #10 |
Drives: VOM 2022 2SS Join Date: Feb 2022
Interesting. I ordered the Ground Effects Kit in Black for SS Models with Quad Exhaust tips. Part No. 84116167. Includes front splitter, side rocker panel moldings and rear diffuser. For use with SS models with quad exhaust tips for my 2022. Cost $2,300 LPO item. Car is in and being PDI/LOP. Along with the New Car acceptance Checklist. This item has been added for checking. I'll be on all fours with the flash light, looking up in these areas for rivets at delivery. I learn something new a lot of times on the Camaro6, Thank you.
05-15-2022, 03:58 PM | #11 | |
Dumb Ass Deluxe
IMO, the dealer installed them incorrectly and the outer "shell" didn't line up with the inner rocker mounted base.
05-15-2022, 08:59 PM | #12 |
Drives: 2019 1SS M6 Join Date: Feb 2020
Side skirts will have Pop rivets holding the rocker brackets, double sided tape, phillips head screws front and back at the wheel well areas.. No chance to come off if installed properly.. Sounds like a warranty issue to me..
1st Gen ground effects kit GBA black , GM CAI , Velossa Ram Air, Expel PPF, illuminated door sills, Upgraded door panels with spectrum lighting
05-16-2022, 04:34 AM | #13 |
Noted: Side skirts will have Pop rivets holding the rocker brackets, double sided tape, phillips head screws front and back at the wheel well areas. Thanks.
05-16-2022, 04:58 AM | #14 |
https://ecom-dam.ext.gm.com/products...s_23433693.pdf
Link above is the Body Accessory Trim Package Installation |
