08-09-2021, 07:57 PM | #15 |
Drives: '18 LT Join Date: Jul 2021
08-09-2021, 08:13 PM | #16 |
You can also get ligher 20" aftermarket wheels that look unique. I had a 2LT V6 with the factory 18" wheels, and I don't think the ride was that much better compared to my current 20" wheels and low profile tires. I will say that I have MRC and switched to non-runflat tires (Michelin PS4S), which made the experience tangibly better.
All that said, the main advantage of 20" is definitely the look, we all know that
08-09-2021, 10:03 PM | #17 | |
Drives: 2SS 1LE Join Date: Oct 2011
The 20s on the 1LE are too big. It really should come with 19s. The 20s are just massively too heavy/large.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
08-10-2021, 07:04 AM | #18 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
As long as your OE brakes can make the ABS do its thing, you don't need bigger brakes for street driving.
Road course HPDE driving is another matter entirely, but there it's more about brake heat management over many very hard stops from high speeds than the once-and-done nature of slower street driving. You're either on the gas or on the brakes, so the brakes don't get as much time in between to cool back down from the higher temperatures involved. Plus, small brakes tend to look lost inside big wheels. Norm
'19 WRX 6M (the family sedan . . . seriously) |
08-10-2021, 07:55 AM | #19 |
Drives: 21 Camaro RS manual v6.Tyota Tacoma Join Date: Feb 2021
Their is a reason autocross drivers like "18 wheels on 6th gen.
08-10-2021, 09:29 AM | #20 |
08-10-2021, 09:31 AM | #21 | |
Great reminder. Something easy to forget when putting a list of mods together. Since this thread is based on looks - OEM LT brakes look like crap. |
08-10-2021, 10:58 AM | #22 |
Drives: On Hiatus Join Date: Apr 2020
Agreed. I would love 19s but with a 35 sized sidewall all the way around. I already run 275/35/20s in the front on 1LE wheels. The 18s I use in the winter are super soft over these trash roads.
08-11-2021, 12:28 PM | #23 |
Thanks for the input folks! Just what I had hoped for.
08-11-2021, 12:57 PM | #24 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
In my personal experience I've found tire type (compound, design, etc) is more important to ride comfort than wheel size and sidewall thickness. Of course this assumes it's all within reason of course. An example would be my 18 inch winter setup vs my OEM 20 inch setup. Both setups have runflats, but the 18's have a 50mm sidewall vs 40mm on my 20's. And in all honesty one doesn't ride any better than the other. Just something to consider when shopping around
08-11-2021, 01:28 PM | #25 | |
Great info - thank you. Coming from the truck/suv world of wheel fitment - still piecing it all together. I Know for a fact I cant fit 37s on this stock set up... |
08-11-2021, 01:37 PM | #26 | |
Best information I can easily find has your 18" tires at 245/50-18 and your 20's at 245/40-20. Sidewall heights would be approximately 4.8" for the 18" and only about 3.9" for the 20's. Both being runflats, sidewall stiffnesses were increased for both, relative to non-runflat tires in those same sizes, in order to carry the load that would no longer be supported by inflation pressure. Norm
08-11-2021, 02:59 PM | #27 | |
08-11-2021, 04:17 PM | #28 |
Monterey County Camaros
I'm running a 20"x9.5" on 275/35R20. Square setup. I have the V6 like you. The wider tires give it a completely different feel. Better planted, able to turn more aggressively with confidence, and just look better overall. Handles fine in that California rain we have out here too (when we have it..)
Follow us on Instagram @montereycountycamaros
Tags |
ride quality, traction, wheels |
