Old 03-27-2020, 05:44 PM   #15
FarmerFran
FarmerFran's Avatar
Originally Posted by 17rsvert View Post
Redesigned? Yes.
Problem fixed? Maybe...
I sure hope so.
Old 07-11-2020, 12:01 AM   #16
MSTRISS
Drives: 2016 2SS Convertible 1980 Z28
Did you ever post an update? This happened to my passenger side while under the bumper to bumper last September. The dealer replaced the whole setup w/rear window reg. Today the driver side let go at 39,395mi and will have to wait till Monday to see what my dealer has to say seeing there is a TSB for this issue and they serviced the other side not even 3500mi ago.
I also use my top a lot and find it discouraging how many people are having this issue with the tops.
MSTRISS is offline   Reply With Quote
Old 08-28-2020, 04:14 PM   #17
srhill44
Originally Posted by Kevin_S17 View Post
Went to the dealer and was told that this has happened enough that there is a TSB for it. Also, there is a “kit” they ordered. When it gets replaced I will post the info from the service invoice.
So this happen to me as well. Found this thread & went off to the dealer. Shared the same info with the TSB & correction kit. Out of warranty for me & was quoted worst case scenario of $1600. Wanted to see what others were paying if not under bumper to bumper.
Cheers
Steve
srhill44 is offline   Reply With Quote
Old 08-28-2020, 10:21 PM   #18
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Cheers
Steve
The new style flapper panel has an extra plastic support. As part of the TSB, the rear window regulators need to be changed. If you don’t want to pay $1600 dollars, forget about the window regulator and snip off the extra support on the new flapper. Replace and be done with it for a few years. $1600 is a rip off...
Old 08-29-2020, 07:24 AM   #19
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
In case you're wondering what the windows have to do with it, the 'fix' for the problem was to add another clip to the top trim piece that contains the sliding cover. The extra clip limits the amount of flex the trim piece sees, lessening the chance of damage to the sliding cover. That clip goes into a redesigned window regulator beneath the trim piece, which has an additional slot to hold the added clip. If you do not replace the regulators also, there is no additional support for the new trim pieces.
I believe I saw new GM trim piece assemblies with the sliding cover available on line for about 80 to 90 bucks each. I have taken mine off and on and it is definitely something that does not require a trip to a mechanic. But a DIY window regulator swap will depend on your level mechanical ability. I've done them before on other cars, it's not impossible.
17rsvert is offline   Reply With Quote
Old 09-28-2020, 08:46 PM   #20
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Mine have been fine for 2 years. Now the passenger panel is loose; i can push the edge closest to the cab down easily & it doesnt sit flush when i put the top down. I hope its just the spring.
classicrockr is offline   Reply With Quote
Old 10-27-2020, 09:16 AM   #21
Nitefall17
Drives: Camaro 1SS A8 Vert
I ordered on off of Ebay, changed it in like 5 mins.....
Nitefall17 is offline   Reply With Quote
Old 11-01-2020, 09:09 PM   #22
classicrockr
Got any tips / instructions for installing?
Old 11-01-2020, 09:21 PM   #23
Jonster
Jonster's Avatar
Drives: 18 2SS Vert Hotwheels
Mine does the same thing. I just push it down and it’s just fine. Instead of messing with it, I’m completely fine just doing that. These tops are one of those “if it ain’t broke don’t fix it” kind of deals. Too many horror stories of tops getting fixed a ton after the first tweak.
2018 2SS hot wheels convertible
Jonster is offline   Reply With Quote
Old 02-12-2022, 06:08 AM   #24
Ssvertlife
Ssvertlife's Avatar
Drives: 2017 Silver SS Convertible
Change sliding door
What’s up bro I know this is old but do you have the steps on how to change the sliding door on the convertibles?
Ssvertlife is offline   Reply With Quote
Old 04-06-2022, 01:03 PM   #25
Vico07
Drives: Chevrolet Camaro 2017 2LT convertib
Fixed it with 3D printed part today. Will see how long this will last.
Video https://youtu.be/cC_HHrBk0dc
Vico07 is offline   Reply With Quote
Old 04-18-2022, 10:06 PM   #26
Vamonos
Drives: 2018 Suburban 2008 Subaru 2017 Cam
Are these tops really that problematic? Wondering if it's worth buying an extended warranty?
Vamonos is offline   Reply With Quote
Old 04-19-2022, 09:17 PM   #27
17rsvert
17rsvert's Avatar
If the sliding covers fail, it does not prevent the top from operating, I would consider it an annoying cosmetic issue. The parts are not extremely expensive, and can be changed out by anyone with moderate mechanical ability. It would be hard to justify the cost of an extended warranty just to cover this potential problem. I have had no problems with the repaired redesigned parts, an no additional problems with my top.
Old 04-25-2022, 04:39 AM   #28
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
And still, no one has posted a part number
truckrglenn is offline   Reply With Quote
