09-21-2021, 06:52 PM | #15 |
Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
09-28-2021, 04:46 PM | #16 | ||
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
So you should have 140ml of wiggle room with two 500ml bottles but that is not much if the old fluid has not darkened enough to be distinguishable from the new fluid. |
09-29-2021, 08:44 PM | #17 | |
Drives: Slow Corolla Join Date: Apr 2021
Is 15 psi OK on the pressure bleeder? I normally just keep filling the reservoir and pump this amount of pressure with an empty bleeder bottle.
‘21 Satin Steel 1LT 1LE
Prior: '22 Camaro 1SS 1LE '90 Mustang LX '18 Volkswagen GTI |
09-29-2021, 11:09 PM | #18 |
Happy to help. Yes that's exactly what I do aiming for about 15psi with the Motive pressure bleeder and it works well. Just remember to depressurize from the Motive side before adding fluid to the master cylinder or some brake fluid droplets might spray around the engine bay. Droplets can be wiped up and washed away with some water (with the master cylinder cap on) if that happens so the droplets don't damage any painted surfaces.
09-30-2021, 11:52 AM | #19 | |
09-30-2021, 01:27 PM | #20 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
On my stock SS 1LE, I used RBF600 for a few years but had to flush it 2-3 times a year. On my current ZLE I use Castrol SRF and flush it annually with no issues. IMHO well worth the extra cost.
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green) Previous cars: - 2018 Miata RF GT (Machine Gray/Auburn) - 2017 Camaro 1SS 1LE (Summit White) - 2008 BMW 135i (Montego Blue) - 1996 BMW 328i (Arctic Silver) |
10-01-2021, 11:49 AM | #21 |
Got it, thanks - I'll give the Castrol a try next time around
