Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 04-01-2019, 06:25 PM   #29
Mcardenal
Mcardenal's Avatar
Drives: 2018 Nightfall Gray Metalic ZL1 A10
OK
My fronts and rears just came in.
Everything looks A-OK
They came sealed in what looks like the original AC Delco/Brembo packaging.
Mcardenal is offline   Reply With Quote
Old 04-01-2019, 06:37 PM   #30
Tabloma
Tabloma's Avatar
Drives: Red ZL1
Note your pad says FF A15, in my post regarding ZL1 vs ZL1-1LE, my original ZL1 pads say FF A17 and the ZLE says FF A18. I am pretty sure thats the compound number still try to verify that
2019 Torch Red ZR1
2015 RED HOT 1LE (traded in)
2018 Garnet Red ZL1-1LE (traded in)
2018 Red Hot ZL1 A10 (traded in)
2015 Z/28 Red Hot w/ GM Wickerbill (traded in)
2009 Siverado 2500HD (Tows and Plows)
2010 Cadillac CTS (Wifes driver)
2004 Corvette Z06 Commemorative Edition (Wife’s car)
2014 Subie Outback (My driver)
Cushman Minute Misers and Scooter
Cushman Minute Miser used parts abundance
ASE Certified Master Mechanic
ASE Certified Master Collision Repair Technician
Tabloma is offline   Reply With Quote
Old 04-01-2019, 06:57 PM   #31
Mcardenal
Mcardenal's Avatar
Thanks for the input.
Did a little digging and it appears that Part# 23337277 is an older part number and is now replaced by Part#23399101. Both part numbers show as compatible with the CTS-V/ZL1..??
As you suggested, going to have to try to figure out how different they are (if any).
Old 04-01-2019, 08:39 PM   #32
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Jumped on GM Parts real quick to check (Dealer only tool) and yes, 23337277 is discontinued/old part number. Replaced by the 23399101 you listed. No info on if there's a design or performance change, it could be that they just changed the numbers.
The prices given in this thread are very good at ~$220 front/$80 rear. That's basically wholesale cost for an authorized GM Parts dealer.
Current OEM ZL1/CTS-V brake pad part numbers:
89047744 - Rear
23399101 - Front
Old 04-05-2019, 01:49 PM   #33
Tabloma
Tabloma's Avatar
Drives: Red ZL1
I spoke to a guy at Hawk tech dept. He said Brembo is super secretive about their compounds, and he has been to Brembo in Italy several times. He said the best he could compare it to would be a Hawk pad, a DTC , 60, 70, or 80, the 90 is what they use on a cup car at a track like Martinsville
2019 Torch Red ZR1
Old 04-05-2019, 01:51 PM   #34
nicktechla
nicktechla's Avatar
Drives: 2012 Porsche 911 Turbo S
I just ordered on GMPartsDirect. I think these are the right numbers
23399101 Front Pads $233.69
89047744 Rear Brake Pads $85.49
IG: 2fast2nick
-- Current --
2012 Porsche Turbo S - PDK - Basalt Black Metallic
-- Past --
2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101
2015 Mustang GT PP - Whipple Supercharger
nicktechla is offline   Reply With Quote
Old 04-06-2019, 01:01 PM   #35
philpacs
Drives: Camaro ZL1 A10
Great info! Question what kind of mileage are you guys out of stock pads. I'm getting squealing now, after three track days and 10K miles. Is that normal and time to replace?
philpacs is offline   Reply With Quote
Old 04-06-2019, 04:23 PM   #36
Badmojo
aka BeastZL1
Badmojo's Avatar
Drives: 2018 Camaro ZL1, 2004 Cobra
The pads will squeal if there is a lot of dust or a heavy transfer layer on the rotors. Inspect the pads and rotors, then clean everything with a healthy spraying of brake cleaner. It is most likely normal.
I replaced my front pads with 4-5mm remaining thickness after 8 track days and 5000 miles. Rears are still in after 10 track days and 6000 miles. Factory pads have 9 mm friction material thickness new.
2018 Camaro ZL1
Old 04-06-2019, 04:33 PM   #37
RUQWIKR
RUQWIKR's Avatar
Drives: 17 SS 1LE & 18 SS Hot Wheels conv
J6H (17+CTS-V, 16+CTS-V): GM / Delco PN's 2339910 / 171-1192 front, 89047744 / 171-0882 rear
They are stamped FER HP1000 at the top (Ferodo HP1000 compound).
RUQWIKR is offline   Reply With Quote
Old 04-06-2019, 10:11 PM   #38
Tabloma
Tabloma's Avatar
Drives: Red ZL1
Everything on yours are exactly like what came off of my ZLE except where yours says "661" Mine says"585". Even the bar code tag numbers are identical.
Not sure what those 661 and 585 mean maybe a date code or batch number
2019 Torch Red ZR1
Old 06-03-2019, 07:12 PM   #39
Mcardenal
Mcardenal's Avatar
Finally getting around to changing the brake pads before i head to the track this coming weekend. However, i noticed the front pads are similar but not the same. It appears as though the slightly older part number pads has a smaller surface area..??
I still have about 7mm left on the original ones so I'm thinking i will just run them and wait for some feedback from you guys.
Old 06-03-2019, 07:18 PM   #40
Tabloma
Tabloma's Avatar
Drives: Red ZL1
I believe I have the original set off my Zle if you are interested, on;y a couple hundred street miles, maybe less 175.00 for front and rear shipped
2019 Torch Red ZR1
Old 06-03-2019, 08:05 PM   #41
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
These are OEM F/R Brembo pads off a 2018 ZL1 1LE?
Very interested, can you post a pic?
Thanks!
SFV1LE is offline   Reply With Quote
Old 06-05-2019, 11:58 AM   #42
BlueinTN
Drives: gas powered
Whats the FMSI part numbers? Usually its a D XXXX
its a much better way to reference brake pads then factory part numbers.
BlueinTN is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
