Old 07-13-2018, 07:47 PM   #29
Markoz28
Drives: 18 ZL1 nightfall grey A10
Excited to see the results.
Markoz28 is offline   Reply With Quote
Old 07-14-2018, 09:25 AM   #30
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
Originally Posted by RabbitZL1 View Post
small update.... i installed a 9.55 lower last week and attemped to try some ethanol. I know its been said that the fuel system cant handle any but i had to see it for my self what exactly runs out. Its a combination of pump and injector. I'll be installing the DSX aux fuel system in a few days and we will see what happens.
Ive heard the stock fuel system is only good to about 650 at the tire with an e85 blend. Would you agree with this from your testing? You are probably right there with the pulley.
Mcmillion is offline   Reply With Quote
Old 07-15-2018, 09:34 PM   #31
RabbitZL1
Drives: 2018 Camaro ZL1
Im way past 650. It made 636 with no pulleys. Tried e50 then down to 39 percent and still no good. Back on 93 and this thing is flying! I wouldnt be surprised if it made 700.
RabbitZL1 is offline   Reply With Quote
Old 09-27-2018, 10:12 PM   #32
RabbitZL1
Im BACK! I know some people were thinking I was gonna disappear Lol.....As some of you know, summer in NY was the shittiest its been in a loong time (heat/humidity) so I havent messed with the car much. Now that its cooler I decided to put the car on the dyno. Since my last big update (9.55 lower) I've added a 2.31 upper, more meth, e85 (60%) and an ice tank. Here are the results:
Im pretty sure this is the highest hp stock blower/stock long block. First pull was actually the very first pull and I was so happy I didnt want to touch the tune. Since I always street tune cars before the dyno very rarely do I have to make any changes. Manifold temps started at 107 and got to 138 by end of the pull. Second pull was a 10 minute cool down with ice packed in the tank. Very happy with the results. Looking to go to a track rental next Thursday. I also tried to spray it on the next pull but low side pressure dropped too much so I let off. Only sprayed it between 4000 and 5000 rpm.
Will be adding a standalone fuel cell I have from a previous build. Next post will be track results
Old 09-28-2018, 01:56 PM   #33
Markoz28
Wow those are crazy numbers!
Keep it up
Old 09-28-2018, 02:32 PM   #34
Fraxum
Fraxum's Avatar
atco is open tonite! Going.
Old 09-28-2018, 03:34 PM   #35
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
My Camaro went 10.03@138 on similar power, your car is heavier so its possible if you can go in the 1.40's on 60 ft you could run that fast on your next outing.
Old 09-28-2018, 03:49 PM   #36
laynlo15
laynlo15's Avatar
For some reason I can't get my picture post but just wanted to help and give my increments for you to get somewhat closer to your goal. I ran in about 70 degree temps. Just comparing your pass at your lower hp/tq.
60 ft 1.471
330 ft 4.22
1/8 6.468
mph 110.38
1000 ft 8.39
1/4 10.03
mph 138.05
1.67
4.63
7.003
106.02
9.037
10.754
133.45
Old 09-28-2018, 04:05 PM   #37
RabbitZL1
Stuck at work smh
For some reason I can't get my picture to print but just wanted to help as give my increments for you to get somewhat closer to your goal. I ran in about 70 degree temps
60 ft 1.471
330 ft 4.226
1/8 6.468
mph 110.37
1000 ft 8.39
1/4 10.035
mph 138.05
Im hoping for a 9.xx but i'll accept a 10.0 lol. Great time! So close to that 9!!
Old 09-28-2018, 04:30 PM   #38
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
So what is the complete mod list now?
djfury05 is offline   Reply With Quote
Old 09-28-2018, 04:37 PM   #39
RabbitZL1
Kong performance ported blower and snout
Katech 103mm TB
Homemade 5" intake
Lingenfelter 9.55 Lower
Kong Performance 2.31 Upper
Stainless Works 2" headers
AEM/Devils own meth kit
DSX Flex sensor Currently on 60% ethanol
Chiseled performance Ice Tank
Nitrous outlet spray bar system (haven't successfully used it yet)
Old 09-30-2018, 02:19 PM   #40
777Jackpot777
777Jackpot777's Avatar
Drives: 2018 ZL1, 2018 Tahoe RST Edition
Awesome build man congrats I’m sub’d! Thanks for all the knowledge.
2018 Camaro ZL1 6MT and 2018 Tahoe RST
Current Mods: ROTO FAB / MBRP Catback
Coming Soon: 9.1 IW / TSP 2" Headers with Catless Connection Pipe / NGK Plugs / Possible Meth injection / HPTuners Tune
777Jackpot777 is offline   Reply With Quote
Old 09-30-2018, 08:40 PM   #41
RabbitZL1
No problem. Always willing to help.....
Old 09-30-2018, 10:18 PM   #42
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
Katech 103mm TB
Homemade 5" intake
Still stock fuel system and just pouring the meth to it? Car is making power for sure. Your car must be the one posted on Kongs FB. Lol
XXX ZL1 is offline   Reply With Quote
