11-11-2023, 11:26 AM | #1 |
Drives: 18 Camaro 2SS Join Date: Jul 2019
Need torque converter, what would you do?
I purchased the car in August of 18 with just under 6000 miles. Sent it with my brother (GM mechanic, in Illinois) for an oil change one day and he also did the fluid change in the transmission because he was aware of the service bulletin on that even though I wasn’t having any issues with it back then. Then I moved to Arizona, where I started having issues with the rear dif, and ultimately ended up having a new one installed under warranty. Now I’m back in Illinois and a couple months ago started noticing the shudder and occasionally a very hard shift. Had tires balanced hoping that was the problem since the car does badly need front brakes. The car sat for a year in AZ till I had it shipped back here to Illinois and I was told the rotors likely warped from sitting, and tires could go off balance from that. Since I won’t be driving it in the winter, I’m not going to replace the brakes till spring just to have them sit and go bad again. Anyway, I took it to the dealership and was told I need a new torque converter. The car was out of warranty in January so it’s all on me. It’s currently got just under 18000 miles. The quote is almost $5000. Only here can I expect you to understand how much I’d like to throw $5000 at this car, but not like this! So the question is - what would you do? Suck it up and pay the dealership? Try to find a smaller shop to do the work? Or ??? I love this damn car too much, and now it’s making me wanna cry.
#girlproblems |
11-11-2023, 11:39 AM | #2 | |
11-11-2023, 12:50 PM | #3 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Agree with above. Never use dealer for anything other than warranty work. You are guaranteed to pay 2X or 3X as much as an independent shop and get subpar work.
ΜΟΛΩΝ ΛΑΒΕ
11-11-2023, 01:09 PM | #4 |
Drives: 2023 2SS Convertible Join Date: May 2009
Did you have the correct fluid put in it? The service bulletin specifies a specific grade of trans fluid that GM developed just to get rid of the shudder problem. When I had the service procedure done on my car the dealer told me it was $20 a quart. I had mine service at 15,000 miles and the convertor was fine, too.
-Geoff
11-11-2023, 01:31 PM | #5 |
Tell that dealer to go pound sand. The nerve to quote $5000 on a $375 part... even with 10 hours of labor, which I highly doubt would be necessary, it should be half of that.
Also, the point Geoff made about the fluid is very salient if your brother performed the fluid change prior to about February or March 2019, because the only correct fluid (Mobil 1 Synthetic LV ATF HP, part number 19417577) came out at the end of January 2019.
11-11-2023, 01:49 PM | #6 | |
11-11-2023, 01:53 PM | #7 | |
11-11-2023, 01:54 PM | #8 | |
The TC replacement should still be way, way cheaper than what you were quoted.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 11-11-2023 at 02:05 PM. |
11-11-2023, 02:01 PM | #9 |
Drives: 2024 ZL1 M6 Vert - Riptide Blue Join Date: Oct 2011
My17 developed that dreaded shutter at 30k miles. Covered under extended warranty was about $4,000 to replace through dealership. Id figure since its a known manufacturing issue that GM would pay to replace those vehicles impacted?
11-11-2023, 03:58 PM | #10 |
I did find (on line) a class action lawsuit about this including the 14 different vehicles this A8 is in, that I believe is in the works in Michigan, but I have no idea what the current status of it is or how to potentially get involved.
11-12-2023, 04:36 AM | #11 | |
Drives: 2023 Camaro LT1 6.2 MT6 Join Date: Jan 2023
FIND ANOTHER SHOP!
I won't let the dealership touch my car unless it's a recall issue, or a warranty repair. I didn't bring my Camaro in for the free oil change. So letting them tear into the transmission is out of the question. Get your car out of the dealership and ask around for a reputable transmission shop. You'll save money, time, and aggravation. |
11-12-2023, 07:01 AM | #12 | |
11-12-2023, 07:28 AM | #13 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
I think most of the cost is the time it takes to take the whole car apart like on a C7 as the whole back end has to come off. Find a speed shop to do the work.
11-12-2023, 09:17 AM | #14 |
Hot Camaro
Long shot...
Call your brother and discuss with him not only what he did but what he may have notated in the file for the car. Since it would have been under the bumper-to-bumper at the time, and it should have been noted that they took proactive action, a failure "now" might be able to be pushed back into the lap of GM to make them cover the repair. |
