06-17-2022, 11:51 AM | #1 |
Cam install
I'm going to have my entire front including radiators off to do a stage 2 FI interchiller upgrade. While I'm there is there a cam or custom grind that I can install w/out the supporting mods and Without taking the heads off? I'm eventually going to do a built motor next year so I'm just looking to get a few extra HP while I got the front off.
06-17-2022, 11:58 AM | #2 | |
'20 ZL1 1LE A10,
06-17-2022, 12:01 PM | #3 |
[QUOTE=JSH;11188405]Lingenfelter has a cam for you, and, unless the Lt4 is different, heads do not need to be removed but you do need to get yourself 16 pen magnets to hold the lifters up while you swap the cam.[/QUOTE
Is there a rod retaining tool for the lt4?I have seen LS rod retaining tools. |
06-17-2022, 12:11 PM | #4 | |
[QUOTE=Dan82679;11188406]
'20 ZL1 1LE A10,
06-17-2022, 12:13 PM | #5 |
06-17-2022, 05:01 PM | #6 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
I would not do a cam without changing lifters, springs, pushrods, and vvt delete at them minimum
06-17-2022, 07:17 PM | #7 |
I have called a few places and no one recommends changing the cam only so I just pulled the trigger on prc aftermarket heads with supporting mods and a Cam. I am currently at 730 Whp on 93 and 780Whp on full E-85(I have port Injection/Kong Xport/Interchiller) I don't want to go over 850-875 to keep things safe with the stock bottom end.If anything I can switch my upper pulley from a 2.3 back to a stock 2.5.
06-17-2022, 08:59 PM | #8 | |
06-17-2022, 09:21 PM | #9 |
06-17-2022, 11:01 PM | #10 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Ha, should of just had CSP do all that when it was there I had a feeling this was coming.... Mines going back in soon for the longblock and port injection. We need to meet up dan.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-18-2022, 10:15 AM | #11 |
All LT engines require pulling the heads for a cam install because the AFM lifters need to be removed and replaced with standard hydraulic lifters...GM choose to use AFM lifter hardware in all engines even if AFM is not active in the tune.
2016 NFG 1SS A8
06-18-2022, 10:53 AM | #12 |
Personally, I have never done cam-only in any engine, but rather always custom valve train. I suspected the LT4 might be different.
'20 ZL1 1LE A10,
