05-09-2022, 06:10 AM | #1 |
Drives: Camaro Join Date: Aug 2021
Weird Vibration
First off. I store my ‘18 Camaro 2SS in the winter and I don’t drive it much. It sits a lot. Garage queen. Lol.
I had a weird vibration yesterday like I drove over bumps on the road. Drove back over that same road and it didn’t vibrate and there’s no bumps. The vibration only lasted for 10 seconds and went away. Was wondering maybe if a brake Caliper/piston got stuck and unstuck. Idk. Before that happened I did a quick 100 mph pull. (Which is just cruising in this car). What do you guys think? |
05-09-2022, 06:28 AM | #2 |
Drives: '22 LT1 Coupe Join Date: Nov 2021
Tire flat spots
05-09-2022, 06:49 AM | #3 |
05-09-2022, 07:36 AM | #4 |
If it is an A8 car it could be the shudder problem showing up?
05-09-2022, 09:41 AM | #5 |
05-09-2022, 10:11 AM | #6 | |
Drives: 2016 2SS Convertible Join Date: Dec 2019
You are probably still under the powertrain warranty, so it should be free. Don't haggle with the dealer on it, the TSB clearly states "no other verification other than customer complaint needed". Make them do it no questions asked or take it somewhere else that will. My wife's '16 CTS4 started doing it at around 40k, and since I was aware of the A8 issue, I took it in and they did the TSB. Hasn't exhibited the issue since, and now at 55k. I had my '16 2SS done even though it didn't have the issue, as a preventative measure. First dealer told me they needed to verify it, I walked. Second dealer said the same until I pointed out the wording of the TSB, then they did it. If you have to pay for it OOP, it's about $450. Have it done at a GM dealer, NOT a 3rd party shop. It takes specific equipment and must be done a specific way per the TSB. A 3rd party shop is likely to just "drain" it and fill it. That may work if you do that completely 3 times, but that's a lot of fluid to buy and dump! Mines a garage queen too! Summers only. 5700 miles on it (in fairness, I bought it in Dec '19 with 1880 miles on it). Drove it in the rain for the first time EVER last week.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
05-09-2022, 10:24 AM | #7 |
Get the fluid flush done ASAP like TP2SS said
05-09-2022, 10:28 AM | #8 | |
Drives: Not yet…. Join Date: Apr 2022
05-09-2022, 10:38 AM | #9 | |
Thanks man. So the shudder starts, like it feels you’re driving over bumps?
05-09-2022, 10:41 AM | #10 | |
Also I have until this December before the 5 year warranty runs out. |
05-09-2022, 10:42 AM | #11 |
Yeah, like driving over the rumble strips on the side of the road. That bad... at least mine was.
05-09-2022, 10:45 AM | #12 |
I didn’t read up on it much yet.
All it needs is a transmission fluid flush? |
05-09-2022, 11:28 AM | #13 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
And don't wait either.
Waiting to long can damage the torque converter.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
05-09-2022, 11:29 AM | #14 | |
If it is early enough, it is a triple trans flush. TL : DR GM put the wrong transmission fluid in the cars, and it has the wrong viscosity. Which causes the shudder and can damage the Torque Converter if letting it go to long.
