07-20-2021, 01:54 PM | #1 |
Drives: A10 ZL1 Join Date: Mar 2018
Toyo 888R’s Tackiness
I’ve put about 4K miles on my Toyo’s and now I’m spinning like crazy at the track. I made two trips to the track when I had under 2500 miles and they hooked great. Is this what I should expect from them? I only made three passes each time at the track and didn’t do a long burnout. 824 Rwhp
07-20-2021, 02:08 PM | #2 |
Could be different track prep, too. A total of only 6 passes with no John Force burnouts doesn't sound like a lot.
07-28-2021, 08:44 AM | #3 |
Nitto 555r2 should be your next purchase.
2016 NFG 1SS A8
08-13-2021, 09:57 AM | #4 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
They don't last more than about 5k miles
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
08-20-2021, 03:46 AM | #5 |
Drives: 2018 ZL1, 2001 Z28 1LE Join Date: Dec 2013
Is this your first time with a higher HP car? If you're getting 5,000 miles out of a set then you're doing phenomenal and most likely aren't racing it much. To put things into perspective, I get 2,000 miles if I'm lucky and stay out of the gas on the HWY and lower speeds. But since I don't and occasionally go to the track (one with turns) I'll usually swap them out at 1000-1500 miles or whenever the start to spin on the street and no longer capable of hooking up. Thats sorta my gauge on when to change or not.
