Old 07-30-2021, 12:42 PM   #57
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
haha yea ill probably be doing 19x11 19x12 but just want to verify the fitment before i actually buy anything
Old 07-30-2021, 06:37 PM   #58
enzia35
Drives: '16 Garnet Red 1SS
Still waiting on an email from them...it's literally the last days of July.
'16 Camaro 1SS
'18 Miata GT
Old 08-05-2021, 12:04 PM   #59
weemus
Drives: 2017 1SS 1LE
I had planned on getting larger ZL1/ZLE fenders to fit the 19x12. In additional camber plates would be used to maximize clearance to the strut. The backup plan was Z06 flares on the wider fenders to ensure minimal poke. I was mimicking the 1Lap1LE setup however he did have MCS struts and my plan would all be on the Mag ride struts... Maybe I need to get some 19x11 as a backup plan and run staggered 305/325 until I am sure it will fit.
Just trying to maximize the contact patch.
Originally Posted by rotis View Post
The zl1 1le fitment on a SS is tough because of the offset. 18x11 +20'ish is a piece of cake with the MCS setup. Right now in front I run 18x12 +15, I think it's possible to do that and still keep it off the fenders. It'll be tight though.
I am at approximately -3.8deg front and -1.9deg rear camber.
weemus is offline   Reply With Quote
Old 08-05-2021, 12:14 PM   #60
kropscamaro16
i have a 1ss with full spl parts and my mcs kit is on the way so im going to try to see if i can fit oem zl1 1le wheels which pretty sure should fit and then also see if i can borrow some 18 or 19x12 to see if itll fit up front without too much poke since my camber should be around -3.5 or more
Old 10-03-2021, 10:40 AM   #61
enzia35
It’s not much but dang they look good.
SM-10 19x10 with 285/35/19 Michelin Pilot Sport 4S. This is the first time I've ever had Michelins. Man they are so nice.
Discount Tire did mention that the stock lug nuts wouldn't work, the socket would hit the wheel.
'16 Camaro 1SS
'18 Miata GT
Old 10-03-2021, 03:32 PM   #62
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
mine at NCM
SM10
TLSTWIN is offline   Reply With Quote
Old 11-19-2021, 08:40 AM   #63
Cjw
Drives: 370z, Srt-6
Anybody know if the standard open apex lugs will work with stock wheels? I recently picked up a set of stock wheels but they’re inbound in my fathers RV, just checking to see if I need to order lugs beforehand, they look similar just wanting to be safe
Cjw is offline   Reply With Quote
Old 11-19-2021, 11:59 AM   #64
enzia35
If they fit the Apex wheels, then for sure they'll work with stock wheels.
'16 Camaro 1SS
'18 Miata GT
Old 11-19-2021, 12:34 PM   #65
Cjw
Drives: 370z, Srt-6
Awesome, thank you for the quick reply
Old 11-19-2021, 02:45 PM   #66
cdrptrks
cdrptrks's Avatar
Open lug nuts may have a smaller cone seat than the stock closed lug nuts. Check the Apex website or contact them to see what they recommend to make sure you don't end up with this issue:
https://www.camaro6.com/forums/showthread.php?t=591822
