Vararam
Old 09-23-2016, 03:01 PM   #253
dookie454
Drives: 2010 Camaro 2SS LS3
Originally Posted by Sakudog View Post
"Some" is said to be about 40-50 rwhp.
My PD blower ZL1 made 775 rwhp @ 17 psi.
My TT ZL1 made 920 rwhp @ 17 psi.
Same cam, Same heads, only change was the removal of the PD blower and the install of the TT setup and a dyno tune for the new setup by the same tuner.
145 rwhp difference and a large chunk of that was due to the blowers drag.
Every Bit helps but turning a blower takes a LOT more rwhp than the electric pump will give you.
Do you have datalogs of this? Curious what the injector flow, airflow, and timing was at for both.
dookie454 is offline   Reply With Quote
Old 09-23-2016, 03:20 PM   #254
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
No, just the dyno data because I do not tune my car, Sam Miller @ AMP does.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 09-23-2016, 04:03 PM   #255
AGP Turbo
Drives: All things Turbocharged
Originally Posted by Nitroman28 View Post
I know this is and old post. But why does your HP drop off at 5600? You would have to shift around 5200 to stay in the power.
Probably way too old a thread here but I just saw this.
You don't shift a car to stay on peak torque, the center your shifts on your HP. HP is acceleration, torque is not. You would shift that car around 6200-6400 for maximum acceleration.
AGP Turbo is offline   Reply With Quote
Old 11-09-2016, 05:53 PM   #256
Fier23
Drives: 2015 Camaro 2/SS M6
ADM Performance just installed an LSA Conversion on my 15' 2/ss.
2.75 pulley stage 3 kit 85lb injectors, ADM stage 2 cam. 665hp 626tq. It's a monster!! 3.91 gears also!
2015 Camaro 2/SS 820hp supplied by ADM Performance
Fier23 is offline   Reply With Quote
Old 11-18-2016, 07:50 PM   #257
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
633hp and 554tq
ECS blower kit, alky control meth Injection, Lashway Motorsports Catch can, QTP cutouts, Circle D triple disc pro series 258mm 2B 32-3400 stall converter, ADM transmission cooler, GPI modified LS3 intake manifold, BoWhite PTB, ARH long tube headers 3" x 1-7/8" catless with xpipe, TSP VVT3 cam and ported heads, SLP 160 Tstat, NGK TR55 plugs, ADM FPCM, ZL1 fuel pump, ID850 injectors, 18" Factory Reproductions style 41 with 265/50 Nitto555 front and 305/45 nitto 555r rear tires, ZL1 3.73 differential, DSS 1-piece aluminum drive shaft, and 1400HP rated DSS axles.
ticowarbird is offline   Reply With Quote
Old 03-27-2018, 01:52 PM   #258
eLeSthree
Drives: 2011 Camaro SS 6sp
ESS Tuning Supercharger Kit (V3si)
You may have seen my recent post, but wanted to keep this in the official "results" thread for those who are shopping.
Ess Tuning Kit (tuner kit) @ 10.3 psi max
226/236 525/525 110 cam and matching beehive springs
TSP 2inch header, 3 inch exhaust
DW90# injector, ZL1 Pump, BAP
Redline Motorsports tune
Land and Sea Dyno-Mite dyno. Going to hit a dynojet and rev to 6800. Post results later.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 05-12-2018, 02:30 AM   #259
ticowarbird
BOHIC
My latest...
What else can I do to my Camaro?
Old 05-29-2018, 12:43 PM   #260
FrankieBee
Drives: 2015 Commemorative Edition
2015 Commemorative Edition-
LS3 D1SC, 4:13 pulley, JDP Motorsports ZR1 blower cam, Fast 102 intake, stock TB, stock heads, ARH with high flow cats, ZL1 fuel pump, AUS 860cc injectors.
Pump gas. Running 9 lbs of boost and no Boost a Pump so couldn.t get a higher number up top.
https://youtu.be/4cPRdkkZL3Q
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ
FrankieBee is offline   Reply With Quote
Old 11-25-2018, 09:55 PM   #261
gbabers
Drives: Yellow SS with RS package
2013 2ss/RS
Maggie - Stock internals
Deka Shorty Injectors 85lbs.
Full 3 Inch Stainless Billy Boat Exhaust with X pipe
DNA headers 1 3/4 not cats
SLP nightwing intake tube w/ stock Airbox -K&N filter
BRE7 Plugs
Taylor Wires
ZL1 Fuel Pump
530WHP - 540TQ - 8 Lbs of Boost
575WHP - 586TQ - 10 lbs of boost - Need new clutch
Mustang Dyno
Flex Fuel should get me over 600HP Really happy with the car now is a daily driver. Reliable, Safe tune.
gbabers is offline   Reply With Quote
Old 01-09-2019, 03:38 PM   #262
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Mods in sig.
Stock bottom end L99, stock intake, stock throttle body.
About 14 psi max Stage 2 ProCharger D1X.
723rwhp pump gas.
760rwhp E85.
Safe DD tune with 13 degrees peak timing.
Before the pulley upgrade:
2010 2SS RS A6 781rwhp on E85
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 02-14-2019, 01:07 PM   #263
CT23
CT23's Avatar
Drives: 13' ZL1 M6
Finally some #'s. Right where AGP told me I'd be when deciding what turbos to go with. This was on 92, correction factor of .98
Was shooting for 14# pull, hit overboost @ 14.9# on this one. Turned the dutycyle down for the next run. Don't have the corrected results on this computer, corrected is about 795.
Still working with Pat G to finish dialing it in. Have the logs if anyone is interested and I can figure out how to upload.
L.O.D. X1 intake and fuel rails, AGP twin turbo kit with Garret turbos GTX3076r .82ar 57/57,Tial 38mm waste gates, Tial Q 50mm bov, Fore duel fuel pump (twin Walbro 430lph) Fuelab 6 micron inline filter, AUS 1400cc injectors, NGK BR7 spark plugs, GP Tuning stg 2 TT cam, ARP headstuds, BTR valve springs and push rods, Smith Bro's brass trunnion upgrade, Monster LT1-S triple clutch, GFB GForce 3 boost controller, SJM line lock, Lingenfelter LNC-2001 2step, PLX module with Bosch O2 wideband, 800ish whp on 92 @ 14psi, 900ish whp on E60 @ 20psi
CT23 is offline   Reply With Quote
Old 09-14-2021, 06:22 AM   #264
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Your corrected numbers on the 2nd run are just uncorrected x .98CF
So turning it down to 14psi netted you SAE 796rwhp/685rwtq @14psi
RealQuick is offline   Reply With Quote
Old 09-15-2021, 03:37 AM   #265
John_C
LSx FTW!!!
John_C's Avatar
Originally Posted by John_C View Post
Mods in sig.
723rwhp pump gas.
760rwhp E85.
Got a trans rebuild and retune by Tim King and it laid down 781rwhp on Speedway pump e85.
Dyno chart and video coming soon as he sends it to me.
HP Tuners VCM Suite
Old 09-16-2021, 08:14 PM   #266
John_C
LSx FTW!!!
John_C's Avatar
2010 Camaro SS
Stock bottom end L99, Stock intake, Stock TB...
Heads, cam w/DoD delete, full exhaust, fuel system and pump Speedway E85.
Built TKR 6L90 with Circle D 3400 stall.
781rwhp
HP Tuners VCM Suite
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 08:57 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 11:00 AM
Really? Why is the DealerInfo Thread Gone? renderinfo 5th Gen Camaro SS LS LT General Discussions 2 02-11-2009 08:01 AM
Changing Photoshop Thread Format headpunter Site Related Announcements / Suggestions / Feedback / Questions 20 11-06-2008 05:40 PM
