09-16-2022, 05:25 PM | #29 |
Here's shots of my Rhodes 7 1/2 gal. tank with internal pump, which leaves you full access to your trunk. Not that I use it much. From start to finish it would be hard for one guy to complete this in one day. Figure two.
'20 ZL1 1LE A10,
09-16-2022, 07:52 PM | #30 | |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
Did you verify that you are logging the correct Manifold Air Temp? There are 2 of them, log them both with key on and disconnect the MAT sensor. The correct one will go to -40 when disconnected. The other one is a calculated value that is normally never very close when the vehicle is modified. I'll post a pull from my Z06 that just happens to be running the same pulley combination that you are.
09-16-2022, 08:08 PM | #31 |
Here is the start of the pull from a cruise with IAT of 79F and a MAT of 120F
Then here is the end of the pull. It's a reasonable boost level (just touching 20 psi at 6500 before the granny shift to 4th), ending the pull with an IAT of 79 and a MAT 100F. If your system is full of water and circulating I'm thinking you're logging the wrong MAT. Let us know what you find...
09-16-2022, 08:24 PM | #32 | |
'20 ZL1 1LE A10,
09-17-2022, 12:27 PM | #33 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 Last edited by MartinLe; 09-17-2022 at 12:38 PM. |
09-17-2022, 12:46 PM | #34 |
No problem, it's an easy check and disconnecting is the only way I've found to make sure I'm logging the right one. That other MAT is a calculation based off conditions of the stock blower to be used as a reference in case the actual MAT sensor fails. As long as the MAT sensor is working the calculation is not used.
09-17-2022, 05:18 PM | #35 |
That's about what mine hit this morning after a bunch of hits. It pulled less than one degree for a MS at peak MAT with no ice in the tank. I'll repeat tomorrow with ice.
'20 ZL1 1LE A10,
09-18-2022, 11:48 AM | #36 |
Loaded a bag of ice, did the usual routine and warmed it up, and at 7,000rpm:
coolant temp 178 boost 17 MAT 135 IAT Advance -0.3 Advance 19.8 10 seconds later - MAT - 110F 20 seconds later - MAT - 95F at 75mph
'20 ZL1 1LE A10,
09-20-2022, 06:19 PM | #37 |
Nice numbers. I wonder? It pulled .3 spark, not much. Not a difference for us not looking for .001's. Are our cars faster with MAT's of 90* opposed to MAT's of 140*? As long as no timing is being pulled, or a tenth here and there, does it make a difference?
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
09-20-2022, 06:53 PM | #38 |
Not as much of a difference on E vs gas. Ethanol is chemical intercooling on its own...drastically lowers EGT's.
2016 NFG 1SS A8
09-20-2022, 07:25 PM | #39 |
I'm on the verge of going to E, but I need to order a BBFP which has an eight-week delivery
'20 ZL1 1LE A10,
