08-25-2022, 07:13 AM | #15 | |
08-25-2022, 07:50 AM | #16 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
You certainly cannot place your former employer, Magnuson, in this category. I was really impressed with the oem caliber fit & finish of my 2300 kit. The instruction book was extremely well done also
Baby Blue
08-25-2022, 07:56 AM | #17 |
Petro-sexual
Dude... that sucks. I'm sorry you had to go through all of that. While I know it wasn't free, at least your shop seems VERY MUCH on top of things, and is getting you squared away, proper. KUDOS to them for actually using their brains (what you pay them for), but more just being a business in it to do good work.
I would have never thought of most of the stuff about the intercooler brick-height relative to draining the tank and all of that. I'm not, and never claimed to be an expert, but it's just amazing the thought the care these good shops put into their customer's builds.
08-25-2022, 08:24 AM | #18 | |
'20 ZL1 1LE A10,
08-25-2022, 08:43 AM | #19 | |
08-25-2022, 09:21 AM | #20 |
I would hit LMP-maryland up if I was in the market for an ice tank. Just putting that out there for those that might be looking into one.
2016 NFG 1SS A8
08-25-2022, 09:50 AM | #21 |
Petro-sexual
I saw that new tank, too. I hadn't, yet, checked to see if it was available though. I almost said something, but you beat me to it.
08-25-2022, 11:46 AM | #22 | ||
08-25-2022, 11:57 AM | #23 |
We've got pumps on supply and return so a small elevation difference is not a critical issue. And we have screened the supply line, but I don't see me putting ice in it very often.
'20 ZL1 1LE A10,
08-25-2022, 12:56 PM | #24 | |
Petro-sexual
14:20 is the trunk tank
08-25-2022, 02:36 PM | #25 |
Lot of good ideas there, except adding a bunch of weight to the nose will tend to hurt traction. I didn't hear him say how many gal. On the other hand, my Eddie probably added 10-15 lbs. and my tank adds 70 lbs to the rear
'20 ZL1 1LE A10,
08-25-2022, 03:33 PM | #26 |
Nothing to do with pumps. The pumps are off when you’re trying to drain the tank down to add ice. Lower tank will receive water from the bricks when you drain the lower tank and send air up to the bricks. If you never add ice than you’ll be fine assuming you can get all the air out…tough to do if the bricks are higher up than the purge point.
08-25-2022, 05:27 PM | #27 | |
'20 ZL1 1LE A10,
08-26-2022, 12:59 PM | #28 | |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
If you are concerned with air in the system, you can add some ball valves (mechanical or electronic) and plum them in your system, so you can close them before draining, and reopen them after filling. |
